Old 11-15-2013, 11:31 AM
Telly Telly is offline
Default Remove Side Mirror 03 TLC?
I broke the glass in my drivers side mirror a couple weeks ago. I just picked up the replacement from Toyota. Looking at the clips behind the mirror, there are tabs on top that slip into the housing and the bottom connectors snaps into clips. Therefore, I assume I pull the broken mirror from the bottom and it should pop out. Anyone have experience with this?
Thanks.
Old 11-22-2013, 04:02 PM
To close the loop on this question, I replaced the mirror last weekend. The method is to pull hard from the bottom of the mirror and it pull pop off. I would not recommend doing this unless the mirror is broken...it's a violent procedure.
