Old 11-22-2013, 06:59 PM
Default Baja California Contact
It was something 2kaa..
Keith and I chatted with him on 147.420 a minute a go from my driveway in boulder.
I guess it was a weird atmospheric thing? Super hard to hear but readable, and we had a short conversation in spanish. He couldn't speak english.
that's a long simplex contact? Or am I nuts? I mean we were talking to him on simplex and he was in Baja?
Old 11-22-2013, 08:03 PM
Seldom Seen's Avatar
QRZ Shows:
XE2KAA,
AREVALO MORENO DANIEL
AVE. CHURUBUSCO NO.1391 COL. CUAUHTEMOC, C.P. 21470
TECATE, BAJA CALIFORNIA, MEXICO.
Gud FM DX. Weird E-hop is my guess.
Old 11-22-2013, 08:07 PM
Keith's Avatar
Keith Keith is offline
On the way home I managed to make a clearer contact, this time with XE2FOX, Miguel. I believe we overheard him talking to XE2KAA earlier. I was using my FT-2900 at 75 watts and we were both able to hear each other really well at points. I think language was more a barrier than the transmission.
____________________
05 Double Cab Tacoma
64 FJ40
KEITH
Old 11-22-2013, 08:12 PM
Keith's Avatar
I think at one point KD0AQA also jumped in. I think he was trying to help translate. He is in Iowa.
64 FJ40
KEITH
Old 11-22-2013, 08:23 PM
Nothing showing up on the spots yet.
Old 12-04-2013, 10:19 AM
That's a cool VHF skip you guys came across. If you look at the solar data 11/22/13 was a pretty quiet day so not sure what phenomenon was at work. NOAA did release a geomagnetic warning on 23NOV2013 at 0800-1700 UTC for a K-index increase to 4, which indicts a pretty active storm in the atmosphere. But there weren't a ton of flares.
http://www.swpc.noaa.gov/ftpdir/indi...1122events.txt
http://www.swpc.noaa.gov/weekly/pdf/prf1995.pdf
Usually VHF and higher just passes right through the atmosphere but low VHF will experience sporadic E-layer reflection, which is a one-hop skip of a couple of hundred miles, and ducting where your signal gets caught in a regional layer that can travel much farther. Our 2m band is really the upper limit for this to happen commonly, it's more likely and almost predictable in 6m and sometimes 10m. It's happened on 70cm but it's extremely rare and once in a while on 1.25m.
Our winter solstice is a common time for a trans-equatorial contact on 10 and 6 because E-layer phenomenon peak during summer. So if the atmosphere is particularly active the region of activity reaches us. If you polarize your antenna horizontally and orient it for north-south, you can almost always count on a contact. This is because the skip generally changes the signal polarity, so a vertical incident wave will end up horizontal.
Being cross polarized (IOW always listening with a horizontal whip when the incident signal has been vertically polarized) means you are giving up 20dB of signal strength. Since a dipole for 2m is only 38" long you can rig one up very easily! 20dB is like using 0.5W instead of 50W or roughly 3.5 S-units, so the field strength goes down A LOT when you're out of polarization.
That you guys had a horizontal-to-horizontal contact indicates it was probably a duct rather than simple skip, which is more unusual and probably due to weather rather than the sun. Thunderstorms will create local skips in the summer, for example you might hear Breckenridge or something else not line-of-sight.
It works very well north due to the semi-permanent nature of the aurora over the pole, BTW. So people with 2m beams will point them towards Russia and northern Europe with some success.
What is also fun is talking FM on 6m and 10m repeaters in New York or Washington... There are I think eight repeater pairs on 10m recommended by the ARRL nationally, so you can monitor them all to see what paths you might have.
