Old 08-30-2006, 03:46 PM
Default Front axle rebuild time: FZJ80
Time to do my front axle rebuild. I just ordered the kit from Cruiser Dan, including the wheel bearings. Just in time for Labor Day weekend.
Ken, can I borrow your 54mm hubnut socket, snapring pliers, and brass drift? I have the rest of the tools on your list. I may go ahead and buy the '96 FSM, depending on the cost. I'd like to have a brass drift too, if I knew where to buy one -- can I get it at Sears?
Has anyone done the 100-series brakes? Just curious how much of an improvement this was.
This may be an amazingly stupid question, but is MolyGrease hard to find?
Originally Posted by nakman
Old 08-30-2006, 03:58 PM
Romer Romer is offline
Matt,
You can borrow my stuff. I bought the drift at Harbor freight. I have done the 100 series brakes. It's suppose to wear better and longer, not sure you can feel any difference.
The FSM is a must have in my opinion, but you could come copy that section in the short term.
I would recommend you call Dan back and order front Rotors as well. You will have it all torn down and only have to do a few extra bolts to get at the rotors, unless they are new. Rear rotors are easy, front rotors require going all the way to the inner bearing/spindle. Only thing not done on the rotor job is the knuckle/birf.
Lock the diff before you pull the axle out, that will make it easier to get back in.
Moly is easy to find in the tubes at any part store.
Old 08-30-2006, 04:22 PM
treerootCO's Avatar
Event Coordinator
My only tech tip....
Don't try and get the last bit of grease out of the tube with your finger. That little metal lid is a sharp sob
www.root45.com
www.risingsun4x4club.org
TLCA #14133
Old 08-30-2006, 04:24 PM
Matt, read Romer's FAQ on mud, it's very well done and comprehensive. You don't need to lock the locker though, that's just on the back. And I use a brass hammer instead of the drift for the cone washers. Gotta get a drift though if you plan on pounding races, unless you can use someone's press? I'll be around all weekend, give me a call if you get stuck on something. Can borrow the FSM if you want, but again all the important stuff is scanned and uploaded on mud.
I got my molygrease at AutoZone.
Old 08-30-2006, 04:32 PM
Rotors, huh? How much will those cost me? Will it be lots less than these:
http://www.man-a-fre.com/parts_acces....htm#dbarotors
for $109 each? I think that what Uncle Ben is running. Uncle Ben, did these increase your stopping power? Anything to increase stopping power is a good thing: my 80 is getting heavier by the minute.
Romer, I'm guessing that you put the 100 series pads on when you replaced the rotors? I've heard that these should be done at the same time.
Snap Ring pliers - do I need to buy these?
Old 08-30-2006, 04:36 PM
There are as many opinions about slotted/drilled as there are holes in the rotors, maybe more. Here's mine: I have them, they stop great, don't get them. The second weekend of May each year is when I remove all 4 tires, then drill out red dirt from all those little holes.
Instead of snap-ring pliers I use a small needlenose, where I ground down flats on the outside of the tips. 60wag taught me that, works really well. Just stick it in, then separate.
Old 08-30-2006, 04:44 PM
I have snap ring pliers and I would buy Toyota Rotors. They will be less than those, don't recall how much though.
I disagree with Tim and advise locking the locker. You probably don't need it, but it doesn't hurt anything and there are a few who have had a problem because they did not.
Old 08-30-2006, 04:56 PM
I concur with Nak....love my slotted/drilled rotors! Stops on a dime with 3 cents change! No pulsating peddle so far even the way I drive! I also have 100 series pads in the front. Locking the locker would have no benefit as either the splines are lined up or they are not and either case a slight rotation of the driveshaft will line it up! Oh and of course I suggest patronizing your local supporting Toy dealers!
Old 08-30-2006, 05:00 PM
only $15... I love this tool. for 15 I wouldn't mess around making a set.
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
Old 08-30-2006, 05:50 PM
So if you had to do it again, you'd stick with the Toyota rotors too?
