Old 12-10-2013, 03:15 PM
LARGEONE's Avatar
LARGEONE LARGEONE is offline
Looks like 400 degrees and 2000 pounds! My plan is to use the teflon...once I figure out exactly what my lengths will be. Where did you pick up your aluminum manifold?
Paul
KE0OLZ
1967 FJ40 - Nearly Stock
http://www.vrbo.com/322094
Old 12-10-2013, 03:20 PM
manifold was an ebay purchase if I remember correctly...
there are tons for super cheap on there:
http://www.ebay.com/sch/i.html?_saca..._skc=100&rt=nc
Old 12-10-2013, 03:22 PM
or amazon if that's yer poison
http://www.amazon.com/s/ref=nb_sb_no...old%20aluminum
Old 12-10-2013, 04:13 PM
I thought the Kilby deal with the mounting bracket, coalescing filter and check valve combo was pretty slick, so I bought their package. Not cheap but a nice setup and it makes it relatively easy to mount the filter to the firewall.
I had these guys make my steel braided hose:
http://www.airbagit.com/v/vspfiles/p...ings_PAGE.html
I think it was ~ $30 for my piece with ends. Unfortunately I estimated a few inches too short but I managed to pull it together with no slack left.
My system still has a couple of leaks, but when that compressor is on the system reaches pressure FAST, and works "optimally" at around 100-110 PSI.
Old 12-10-2013, 08:20 PM
Inukshuk's Avatar
Inukshuk Inukshuk is offline
Do you need a triple pulley? I may know a guy with one.
Old 12-11-2013, 10:03 PM
LARGEONE's Avatar
http://www.amazon.com/Unisource-Chem...6+3%2F8%22+NPT
Man...I already purchased my PTFE hose material and AN 6 ends, but then I came across this hose option on Amazon. Already has NPT fittings on the end which is really nice and not too bad a price....lots of length options too! Oh well!
Paul
KE0OLZ
Old 12-11-2013, 10:05 PM
LARGEONE's Avatar
I have one that came with my bracket, but you should really see what you can get for it on Mud...there are always people who miss the group buys that are offering up their houses and millions of dollars for a triple pulley!!! Seriously, you could probably get a lot of money with a bid war on that thing!!!
Paul
KE0OLZ
Old 12-29-2013, 08:38 PM
LARGEONE's Avatar
Default Plumbing left to do
I finally got some time over the last few days to get the York mounted. I ran into issues with the bracket I bought through MUD...the pulley and bracket were kind of skewed and didn't line up right with the fan pulley. Thanks to a post by our own Jacket, I was able to space it out a little bit with a couple of washers. It looks pretty good now.
So, now I just need to figure out how I want to run all my plumbing...for the air horn, the gauge in the cab, and for the lockers! Lots of fun stuff!Name:  York 210.jpg
Paul
KE0OLZ
Old 12-30-2013, 01:30 PM
Nice. The plumbing is a pain in the ass....
One thing I noticed on mine was after I added the washers, the nut that holds the adjuster pulley in place was only about 2/3 of the way on the threads. I added a little non-permanent Loctite to make sure the nut doesn't vibrate off.
Old 12-30-2013, 09:49 PM
LARGEONE's Avatar
Thanks Matt. I actually ended up not spacing my pulley...only the two bracket bolts on the engine closest to the front of the engine.
My plumbing is REALLY a PIA because I have the air horn and in-cab line.
Paul
KE0OLZ
