Old 12-30-2013, 11:15 PM
jps8460's Avatar
jps8460 jps8460 is offline
Commander
I'm sure this has been beat to death somewhere, just though I would toss it in because the info saved us from loosing a feature win due to a dry sump pressure line leak......
most parker/gates hose places sell sae37deg/JIC fittings/hoses that will work interchangeably with any -AN fitting you buy. they are steel, heavy and not as nice looking, but it gets the job done.
A tractor supply store with a gates crimping tool and nice hose selection saved our butts in the middle of nebrasky
Old 03-17-2015, 09:50 PM
LARGEONE's Avatar
LARGEONE LARGEONE is offline
Just want to add that I used Loctite 545 on my air fittings and it has really helped with air loss in my OBA setup. I still have some loss from my crappy check valve, but my fittings are solid due to the Loctite. It's made for hydraulic fittings.
Paul
KE0OLZ
1967 FJ40 - Nearly Stock
http://www.vrbo.com/322094
Old 03-18-2015, 09:51 AM
baja1d's Avatar
baja1d baja1d is offline
Good info... Just picked up a York yesterday
Travis Hurley– Owner/ C.E.O.
