Go Back   Rising Sun Member Forums > Toyota 4x4 > 4Wheeling and Event Staging Area
Old 01-14-2014, 03:25 PM
MisledYouth's Avatar
MisledYouth MisledYouth is offline
I'd love to bring the 40, but I doubt it'll be done by then. If I CAN make it, I guess I'll have to settle for heated seats and a heater that works. Weeeeaaaaak.
Zach Feiler | Littleton, CO
3rd Battalion 5th Marines India Company 2005-2009
"Get Some"
1979 FJ40 - "The Phun Express" - Smurf blue
- 5.3 Vortec - 4L60E - Orion 4:1 -SOA front / 4-link rear - FJ60 axles - ARB's - 4.88's - 37's
1999 UZJ100
- factory locker/ARB front - 285/75r16 Duratracs - Slee 2.5" Heavy Kit - Slee Blueberry/Warn VR10000 - Slee tube sliders - EMS cat-back
Old 01-16-2014, 08:59 AM
treerootCO's Avatar
Event Coordinator
Here is a short clip of some wheeling on the same trail 1/1/2014.
www.root45.com
www.risingsun4x4club.org
TLCA #14133
Old 01-19-2014, 11:09 PM
DHwreckage DHwreckage is offline
was just up at yankee hill friday night, so i broke the trail for you guys ! but ill be looking to make this run. need to break in the new cruiser more!
  #24
Old 01-21-2014, 09:09 PM
imhighlander's Avatar
Hope this isn't a thread jack but what is the lowest psi you can run on a stock, non-beadlock wheel? I'm in an 80 on 285/75/16 with the OEM wheels. Would love to try and make this run but am afraid of getting stuck. (Happened once on Kingston Peak in a wicked drift on the shelf road.)
___
TLCA #22433
1993 FZJ80: the Green Chile
  #25
Old 01-21-2014, 10:07 PM
Should be plenty of support there to help you get unstuck.
"Get Some"
1999 UZJ100
  #26
Old 01-21-2014, 10:20 PM
I would suggest no lower than 15psi, and would probably stop at 17. It's possible to get a bit more traction going lower, but it's not worth the additional potential sidewall damage, IMO... remember there's pokey things down under that snow. Getting under 20 is going to get you pretty squishy as it is, staying towards the back should make sure you "make it" more often than not, and above all else make sure you've got solid recovery points front and back.
A great thing to do while airing down is just hook up a strap in back, put a shackle in the other side, then toss it inside through the hatch. That way should you need a tug in reverse, or should the guy behind you need a tug, you're already ready.
  #27
Old 01-22-2014, 08:31 AM
Thanks, and sorry for another noob thread jack. I have stock bumpers and only have the tiedown points on the frame and a receiver hitch with a D-shackle plug. Is this adequate? Hopefully this spring I can weld up some "proper" recovery points to the frame. I'd love to upgrade bumpers but that's too spendy for me right now.
___
TLCA #22433
  #28
Old 01-22-2014, 10:15 AM
Yes you will be great. Your best recovery point is the receiver hitch, in fact you don't even need that shackle plug you can just slip the receiver pin through the loop on the strap- that's what I use whenever possible. In front, those loop things should be good, take a peek at them to make sure they don't look too rusty as yes, we had one of those break on a run last year. Definitely don't want to jolt the truck when using those.
When you upgrade, look for the URB- universal recovery bracket. I think Jonesy's sells them? they have a banner here... http://www.jonesysoffroad.com/toyota-land-cruiser-urbs/
or just get a Slee bumper . Either way it's worth upgrading your front points at some point, then you'll be ready for anything. And don't sweat the hijack! 4 other people probably had the same question, but were too shy to ask. this is why we have this forum.
  #29
Old 01-22-2014, 01:46 PM
Sweet. Thanks again.
___
TLCA #22433
  #30
Old 01-22-2014, 03:24 PM
FJCDan FJCDan is offline
Default Snow run
There are always plenty of veterans on this run so you can be positioned between those. As far as tire pressure I have 285 KM2's and I run as low as 10-12 psi and never had any issues. This is great run to learn what your truck will do in the snow. And by the way if you don't get stuck your not trying hard enough. Have fun I know I will.
