Go Back   Rising Sun Member Forums > For Sale + Help > Rising Sun Forum Help Corner
Old 01-26-2014, 07:40 PM
DanS's Avatar
DanS DanS is offline
Default Signature length (?)
Signature text length....
Any way to allow it to have longer text length within URLs? I don't want to have a tome for the signature, but I would like to add another line, with a URL to the build thread on MUD, and I currently can't.
Dan
Old 01-26-2014, 08:52 PM
ianacole ianacole is offline
Send a message via AIM to ianacole Send a message via MSN to ianacole Send a message via Yahoo to ianacole
Is it limited to 4 lines, or # of characters? If characters, try using a shorter label in the link tags:
Replacing the Braces with Brackets in this:
{URL="http://www.ih8mud.com"}CLICK{/URL}
Will result in this:
CLICK
Ian A. Cole
Blue '73 FJ40 - My DD
Blue '06 Tacoma Quad Cab 4x4 longbed - 's DD
Old 01-26-2014, 09:30 PM
Yeah good tip Ian. Use that little "insert link" icon as you highlight stuff in your sig, then just link those words elsewhere. Example:
Dan's 40. 3B Turbo project, and Dan's 60.
Old 01-27-2014, 01:07 AM
Rising Sun Webmaster
Dan, advice above is solid. If you do prefer to post URLs instead of linked words, you could also use a URL shortener:
http://goo.gl/
https://bitly.com/
Old 01-27-2014, 06:07 AM
DanS's Avatar
CLICK
http://goo.gl/
https://bitly.com/
Very good. That explains why I've had issues. I have just typed the BBcode with the braces, and interestingly enough it clearly processes that differently than if I were to use the link icon to do the same.
Thanks guys!
Dan
Old 01-27-2014, 07:45 AM
To be clear, the actual code should use brackets, not curly braces. It should look like the image I have attached below.
The result will look like this:
1976 HJ-45 (needs restoration)
It may be that the link icon doesn't work correctly in the sig line edit window, but if you use the code it should work fine.
Old 01-28-2014, 12:42 PM
DanS's Avatar
No idea, I thought I had tried that previously.
Problem solved though. Much cleaner looking.
Dan
