Old 01-30-2014, 09:51 AM
ttubb's Avatar
ttubb ttubb is offline
Default Valve Cover Vent Mod
My son, Justin (Taildragon) alerted me to a mod some of the folks back east have done to reduce deposits in the intake manifold and throttle body. It is a simple process involving cutting a hose and inserting a small filter in the line. I got all the parts from Harbor Freight for less than $11.
Parts -
2 ea 68211 barb fitting with clamps - $1.99 ea
1 ea 68225 Mini Air Filter - $6.49
The air filter is designed to be under pressure so you must block the drain port to prevent air from being sucked in. I did it with a small section of plastic hose with a rivit inserted in the end.
The interesting thing is that after a day of wheeling, I had over a quarter of an inch of oil in that bowl.
Simple fix, works great! Terry
KA7TLT - TLCA 13015
Old 01-30-2014, 09:57 AM
baja1d's Avatar
baja1d baja1d is offline
Which engine is this for?
Travis Hurley Owner/ C.E.O.
Old 01-30-2014, 10:03 AM
ttubb's Avatar
Sorry, this is on a 95 FZJ-80. T
KA7TLT - TLCA 13015
Old 01-30-2014, 06:19 PM
seems like if you had that much oil in there you would have had a series consumption issue prior?
Old 01-30-2014, 07:42 PM
ttubb's Avatar
Nope. This just captures the oil that would normally be vaporized and sucked into the intake system. The tube is there from the factory, the filter/bowl just recaptures it.
KA7TLT - TLCA 13015
Old 01-30-2014, 10:46 PM
Inukshuk's Avatar
Inukshuk Inukshuk is offline
x2
Old 01-30-2014, 11:32 PM
Yah, but if that much oil got vaporized all the time you'd be a quart low in no time?
Old 01-31-2014, 07:55 AM
ttubb's Avatar
You are forgetting this line is open from the factory. The filter and bowl only recapture vaporized oil so it does not go into the intake. It does not increase oil consumption.
KA7TLT - TLCA 13015
Old 01-31-2014, 08:13 AM
It's not that it's increasing consumption but that if you have that much oil being vaporized then you have something causing it in the first place. That seems like a lot of oil to burn up in the course of a day. If I lost that much oil daily in my 22R I'd have none in the crankcase after a month.
Old 01-31-2014, 08:44 AM
J Kimmel J Kimmel is offline
this mod doesn't increase consumption but if your engine is vaporizing that much oil to begin with you might have a consumption problem
