Old 02-11-2014, 06:57 PM
Not on a 2F
Old 02-12-2014, 01:31 PM
PabloCruise's Avatar
Not on a 2F
Right. Those come out the side of the valve train pushrod cover.
Apparently the top of 2F heads are much cleaner than the top of the 3FE heads due to this...
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
Old 02-12-2014, 04:01 PM
I should have remembered that. My last 2F is becoming a distant memory. All of my current engines have the valve stuck in the valve cover.
If the flow of the PCV system is out the PVC valve to the intake manifold, why would the top of the head be any cleaner with the valve in the side cover? It's not like there isn't a bunch of oil already up there. I can see how there might be oil crud building up in the intake manifold.
