Old 02-01-2014, 02:50 PM
ianacole ianacole is offline
Send a message via AIM to ianacole Send a message via MSN to ianacole Send a message via Yahoo to ianacole
Default Shop Recommendation for Electrical Work?
'73 FJ40, SBC, TBI, dual battery
Background: I had the FJ at a collision repair shop to do some work following an incident. I got a call from them as they were wrapping up the repair that they kept blowing fuses (20Amp) and ended up frying the TBI ECU (I paid for a replacement). They couldn't figure out what was going on, so I got it home. Turns out that the voltage regulator in the alternator had gone TU, and they were driving it and running it with over 18 volts being pumped back into the system. It pegged out the volt meter on the dash.
I've replaced the alternator and the battery, but now am seeing only 10 volts back into the system. I suspect that the battery isolator is not performing properly but have not had the time to replace it to see if that's the source of the current issue. Regardless, it's still not running right.
Fast forward to today: I contacted our insurance company that covered the incident and they told me that in order for them to cover it I needed to take it to a shop to have the issue diagnosed and an estimate for repairs. Anyone with a recommendation? It's NOT going back to the collision shop.
Ian A. Cole
Blue '73 FJ40 - My DD
Blue '06 Tacoma Quad Cab 4x4 longbed - 's DD
Old 02-01-2014, 09:41 PM
baja1d's Avatar
baja1d baja1d is offline
PM sent
Travis Hurley– Owner/ C.E.O.
Old 02-01-2014, 09:49 PM
Thanks!
Ian A. Cole
Old 02-02-2014, 10:29 PM
LARGEONE's Avatar
LARGEONE LARGEONE is offline
Was there a shop recommendation?
Paul
KE0OLZ
1967 FJ40 - Nearly Stock
http://www.vrbo.com/322094
Old 02-03-2014, 03:08 PM
MisledYouth's Avatar
MisledYouth MisledYouth is offline
Not sure what happened with this, but Chris at The Edge Automotive hooked up my FJ40 electrical stuff. Apparently, Proffitt's left most of the grounds on my vehicle dangling when they deemed it "ready for pickup". Found a few, took it to Chris, who found many more. I still wish there was somebody left at Proffitt's so I could kick their door in and get my 45k back. Anyway, Chris is a great guy. Give him a call if you haven't found someone.
Zach Feiler | Littleton, CO
3rd Battalion 5th Marines India Company 2005-2009
"Get Some"
1979 FJ40 - "The Phun Express" - Smurf blue
- 5.3 Vortec - 4L60E - Orion 4:1 -SOA front / 4-link rear - FJ60 axles - ARB's - 4.88's - 37's
1999 UZJ100
- factory locker/ARB front - 285/75r16 Duratracs - Slee 2.5" Heavy Kit - Slee Blueberry/Warn VR10000 - Slee tube sliders - EMS cat-back
Old 02-03-2014, 03:43 PM
baja1d's Avatar
I had sent him the info for Brian... He's the guy that is rewiring my 4runner. I can forward his info to anyone that needs it via PM.
Old 02-03-2014, 04:54 PM
Thanks Zach! If Brian is unavailable I will give Chris a call.
Ian A. Cole
