Old 02-10-2014, 09:01 PM
Inukshuk's Avatar
Inukshuk Inukshuk is offline
Talking You know your truck is old when ...
You wear out the spring to the fuel door.
Miles 250000
MPG (avg) 11
Gallons used 22727
Tank size 22
Minimum Full tanks used 1033 = minimum cycles.
That should not have failed.
Old 02-10-2014, 09:09 PM
Disappointing
Haha, mine will wear out in another decade when I hit 250,000. Most of my miles these days are for CM and the Outlaws run.
Old 02-11-2014, 08:36 PM
LARGEONE's Avatar
LARGEONE LARGEONE is offline
The title should have been..."you know your truck gets really bad gas mileage when...."
Just kidding Daniel!
Paul
KE0OLZ
White 2008 GX470 - Nearly Stock
http://www.vrbo.com/322094
Old 02-11-2014, 11:23 PM
Inukshuk's Avatar
DOH! I was figuring others would post their oddball worn out parts. Really, who breaks a fuel door spring? Courtesy light switches ok (and they are bad on 80's apparently)
Old 02-12-2014, 09:16 AM
My '99 Camry fuel door spring was broken at 197K. It was all plastic. The replacement spring from Toyota was plastic and stainless steel (as it should have been). All my other Toyotas have stainless springs.
Old 02-12-2014, 09:45 AM
MountainGoat's Avatar
Club Treasurer
I disconnected my 80's front door switches a couple of years back when they became unable to determine when the door was closed.
Dan Kucera
TLCA# 17536
KDWJO
67 FJ40 LC Tan
95 FZJ80 LC Red
99 UZJ100 LC Black
Old 02-12-2014, 11:49 AM
fixed..
You don't have a spring to the fuel door.
