Old 02-12-2014, 07:07 AM
You can try adding a fluid heat riser and see if that helps
Old 02-12-2014, 10:21 AM
I would check your intake manifold for a crack in the cast area directly under the carb (in the casting which separates the intake from the exhaust), which my '78 had years ago.
Old 02-12-2014, 10:50 AM
cbmontgo's Avatar
cbmontgo cbmontgo is offline
Thanks, guys. I think I am going to leave things as they are since this will primarily be a summer rig anyway. Steve, the intake area you refer to looks fine; no cracks.
Sounds like the problem was just my getting used to the time it takes for aftermarket headers to heat the intake manifold and vaporize fuel in the winter.
Now, if summer can just get here a little faster...
