  #31
Old 05-18-2014, 02:45 PM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
and here is when I pulled off the bed, and started the sanding process... and the last picture of the cab 1/2 sanded is ware I sit now.
the air compressor I was using took a poop. and because its one of those fancy rotary screw compressors with A/C and DeHumidifing built in, running off of 3 phase.. we have to waite for the service tech to come fix it..
TLCA # 20314
Step by Step Bed Bob
  #32
Old 05-18-2014, 02:48 PM
TIMZTOY's Avatar
the Yellow is the OEM frame, and the rear outriggers are for the leaf spring rear mount.
the whole thing only weighs 177lbs with out welds
gray is DOM, blue is HREW, orange is 1x1 square
and this ware I sit now....
oh yea a teaser shot of my truggy design.. and im still going to use chevy 63" in the rear for now.. and ill just cut off the outriggers when I can afford the coil overs..
TLCA # 20314
  #33
Old 05-18-2014, 10:00 PM
Disappointing
Dude, you have been hard at work. That frame rust is nasty!
Originally Posted by nakman
  #34
Old 05-19-2014, 06:05 PM
TIMZTOY's Avatar
yes.. yes it is.. that last picture that appears to be a selfie, is the front leaf spring hanger.. and the worst location is at the firewall area on the frame. that's the worst location and its going to require a lot of fabing.. basically a complete rebuild
TLCA # 20314
  #35
Old 11-08-2014, 07:45 PM
TIMZTOY's Avatar
its been a while since I have made progress on the truck.. sorry if you were following this thread and nothing happened.. but work has been super busy and ive had very little time to work on it.. only about 6-8 hours a week is all... and that's provided I get the time to sneek into the shop.
but I finally have the entire truck sanded down with 150 then 320 grit. door jambs, hood jambs, every nook and cranny.. excpt the engine bay. next step is assemblying the make shift paint booth and spraying the primer.
TLCA # 20314
  #36
Old 11-09-2014, 12:49 AM
RedCreeper's Avatar
Dont think the glass cleaner will be much help....
Kenny Jones
TLCA #19056
08 TT FJC
82 Scrambler (Scraps)
81 Scrambler (Sassy)
07.5 Dodge Ram 2500
  #37
Old 11-16-2014, 03:53 PM
TIMZTOY's Avatar
Talking
Mr funny guy huh.
TLCA # 20314
  #38
Old 11-16-2014, 03:55 PM
TIMZTOY's Avatar
Got it all primed.
TLCA # 20314
  #39
Old 11-16-2014, 03:57 PM
TIMZTOY's Avatar
Look at that roof now !
TLCA # 20314
  #40
Old 11-16-2014, 03:58 PM
TIMZTOY's Avatar
TLCA # 20314
