Old 02-24-2014, 09:39 AM
treerootCO's Avatar
Event Coordinator
Default 57" Hitachi - Denon 7.1 Receiver and DVD player
Selling my Home Theater. Perfect for a basement or dedicated gaming/kids room. The TV is a 57" 1080i in perfect working condition. The only reason I am selling it is because I want something smaller. The DVD player is a Progressive Scan 1080P and the receiver is a 7.1 with 110 Watts per channel. The receiver has multi-room so you can play one source in one room and a different source in another. I think $500 for all of it sounds fair. Let me know.
Hitachi 57" Rear Projection
Model #57SWX20B $3000 new
http://www.manualslib.com/manual/680...0b.html#manual
57-inch 16:9 rear-projection HDTV monitor with full 1080i resolution; 54 x 54.19 x 25.5 inches (W x H x D)
1,280 horizontal lines of resolution
HD Hybrid wide-neck CRTs and Super Contrast 5-element lens system is optimized for HDTV-level programming
Anti-reflective high-contrast shield offers 160-degree viewing angles and minimizes ambient-light distortions
Magic Focus 8-sensor auto digital convergence saves configuration efforts
Denon 7.1 Audio/Video Receiver
Model # AVR-3802 $899 new
http://usa.denon.com/DocumentMaster/...nersManual.pdf
Product Description
Built-in decoders-- DTS Neo:6, DTS decoder, Dolby Digital, DTS-ES decoder, DTS-ES Matrix 6.1, Dolby Pro Logic II, Dolby Digital Surround EX Amplifier Output Details-- 110 Watt 8 Ohm 0.05% 2 Front Installed, 110 Watt 8 Ohm 0.05% 1 Center Installed, 110 Watt 8 Ohm 0.05% 2 Surround Installed, 110 Watt 8 Ohm 0.05% 2 Surround back Installed, 150 Watt 6 Ohm 0.7% 2 Front Installed, 150 Watt 6 Ohm 0.7% 1 Center Installed, 150 Watt 6 Ohm 0.7% 2 Surround Installed, 150 Watt 6 Ohm 0.7% 2 Surround back Installed, 140 Watt 8 Ohm 2 Main Installed, 210 Joules 4 Ohm 2 Main Installed, 240 Watt 2 Ohm 2 Main Installed
Signal-to-noise ratio-- 102 dB
Optical Digital Input-- Yes
Coaxial Digital Input-- Yes
MD system type-- None
Denon DVD player
Model # DVD-1600 $329 new
http://www.manualslib.com/manual/228...-Dvd-1600.html
A solid value for home theater and music enthusiasts alike, Denon's DVD-1600 delivers high-end picture quality, high-end sound, and impressive playback flexibility. Its selectable component video output lets you choose between progressive or interlaced mode. Progressive scan lets you enjoy a remarkably detailed, filmlike picture with your HDTV-ready TV, thanks to a 54MHz/10-bit video DAC and Faroudja's superb DCDi™ de-interlacer with 3-2 pulldown processing. Or you can select interlaced output for great performance with a standard TV.
The DVD-1600 is an exceptional audio player as well, fully equipped to wrap you in gorgeous multichannel sound. Built-in Dolby® Digital/DTS® decoding sends 5.1-channel sound to any 5.1-ready receiver (or let your Dolby Digital receiver do the decoding). Multichannel DVD-Audio playback surrounds you with up to 6 channels of high-resolution music. (Though there's a limited selection of DVD-Audio titles available now, you can expect to see lots more from this up-and-coming format.)
You also get playback for regular CDs, audio CD-Rs and CD-RWs…even MP3 files stored on a CD-R! And thanks to this player's high-quality 192kHz/24-bit D/A converters, count on smooth, clear sound from your whole disc collection.
Details:
plays DVD-Video, DVD-R, and Video CD
plays DVD-Audio, CD, CD-R & CD-RW, and MP3 CD-R & CD-RW
54MHz/10-bit video D/A converter
selectable interlaced/progressive-scan component video output (progressive-scan requires an HD-compatible TV)
Faroudja DCDi de-interlacer with 3-2 pulldown processing
3MB buffer for quick layer change
Virtual Surround Sound for enhanced 2-speaker sound
optical digital output for Dolby Digital/DTS/PCM (96kHz/24-bit capable)
built-in Dolby Digital/DTS decoder with 5.1-channel output
bass management for Dolby Digital, DTS, and DVD-Audio
Audio Only mode switches off video circuits when playing DVD-Audio discs
2 sets of A/V outputs (2 composite video, 1 S-video, and 1 480i/480p component video)
headphone jack with volume control
192kHz/24-bit audio D/A converters
audio signal-to-noise ratio 115 dB
17-1/16"W x 3-1/4"H x 11"D
warranty: 1 year parts & labor
designed for use with "Region 1" coded DVDs
www.root45.com
www.risingsun4x4club.org
TLCA #14133
Old 02-27-2014, 01:48 PM
treerootCO's Avatar
Event Coordinator
Perfect stereo for the garage
www.root45.com
TLCA #14133
Old 03-02-2014, 11:34 AM
treerootCO's Avatar
Event Coordinator
I have the original boxes and owner's manuals. Let me know if you are interested.
www.root45.com
TLCA #14133
Old 03-10-2014, 04:54 PM
treerootCO's Avatar
Event Coordinator
http://denver.craigslist.org/ele/4368981909.html
www.root45.com
TLCA #14133
Old 04-12-2014, 10:21 PM
maxsdad maxsdad is offline
Hey Mike - Have you still got the receiver and the DVD player?
HTML code is On
