Old 02-26-2014, 06:27 PM
I actually looked this morning on SOR to see if there was an OEM solution. For 77 there isn't but for '78 and on there is. So since I have a '79 dizzy I might give it a try.
I'm pretty sure I have one you can try/have Matt. I'm going to try to make the meeting this month.
Old 02-26-2014, 08:57 PM
What makes you so sure it was electrical?
I guess that was just my first thought since folks mention waterproofing the distributor etc for water crossings. Symptoms seemed consistent in my mind. But some of the explanations on this thread make sense too
Old 02-26-2014, 09:00 PM
Originally Posted by SteveH View Post
Certain domestic trucks will flood badly after you shock the carb with a hard hit - is there a chance that you're hitting these drifts hard enough that you're simply massively flooding the engine? I personally doubt this, but thought I'd put it out there. It's pretty hard to upset an OEM Aisin carb.
Yep, stock Aisan. I was able to roll all the way through the snowdrifts so they were soft so there was no shock or bashing per se. In fact one section was just hitting some snow on the side of the road that drifted up and into the engine bay
Cool, thanks Martin! I will try to make it then as well
Old 02-27-2014, 05:46 PM
PabloCruise's Avatar
How old are the wires? Old wires can be sensitive to moisture. Do you put anything in the boots to seal against the plugs and cap terminals? I think you can run some di-electric grease to help with the water-proofing...
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
