Old 04-16-2014, 02:12 PM
Rezarf's Avatar
Rezarf Rezarf is offline
Default Help starting engine that's been sitting for years... Ford Sraight six
My neighbor has a 82 Bronco with a straight 6 engine in it. He's been trying to get it started for a few days and I poked in and tried to help yesterday for a few minutes. I could get it to fire and stay running while injecting starting fluid in the carb, but as soon as we stopped spraying the engine dies.
They've had the same gas in it for 2 years I suggested draining the gas in the thank then putting in some new high octane with a can of octane boost in it and see if it would fire. Well, they didn't drain out the old gas first they just added 5 gallons of fresh and a can of octane booster. The gas tank had about a quarter tank before adding anything.
It still won't fire. I know the following for sure...
Fresh battery
Fuel to the carb
Fuel is being pumped into the carb
Good spark
Runs on starting fluid
I am assuming it has to be fuel related but I am not sure if what they did was able to bump up the bad gas to something usable?
I'm just trying to help the family out, any suggestions?
Rezarf <><
K0RZF
My rig... "Maude"
Old 04-16-2014, 03:38 PM
RicardoJM's Avatar
Drew, did you check/see if the accelerator pump is delivering a squirt?
While it may look different, the carburetor should behave the same as the ones on our 40, i.e. there should be a squirt of gas down the primary when you hit the pedal.
Ricardo Maestas - Bio Page
KD0CAW
1999 LX 470
SOLD - 1971 FJ-40
TLCA #18941
Old 04-16-2014, 03:44 PM
The carb jets are likely clogged with old gas residue.
Old 04-16-2014, 04:05 PM
J Kimmel J Kimmel is offline
pull that carb apart completely and clean it within an inch of its life
Old 04-16-2014, 04:15 PM
Be sure the choke is fully closing, and I'd vote for clogged main jets or a stuck float.
Old 04-16-2014, 09:16 PM
jps8460's Avatar
jps8460 jps8460 is online now
Commander
X2 for stuck float.
Also, those old ford ignition modules we notorious for acting wierd.....ie if the engine will only fire with the key in the start position, but not in run, I would have the ignition module tested
Old 04-16-2014, 11:16 PM
if you can get it to run... rev it till its gonna kill itself then slap yer hand on the carb to where it feels like its gonna do an airplane suck your ass into the lavatory move. The suction can sometimes pull trash through the jets and let fuel start to move normally through it again.
Old 04-17-2014, 09:28 AM
MicahMan's Avatar
MicahMan MicahMan is offline
Default Like It
Best explanation of vacuum charging I've ever heard. This is exactly what I did when my 40 was first firing up after 15 years of hanging out in a horse corral.
Old 04-17-2014, 10:09 AM
that's an Okie carb rebuild
Old 04-17-2014, 10:36 AM
Yessir, an if it don't work then do the following:
