Old 04-07-2014, 03:22 PM
CardinalFJ60's Avatar
Default APRS no workie
none of my APRS units seem to be logging a beacon at APRS.fi nor openaprs.org. I have an HT and a Byonics TT3...neither of them show online and I've been messing with them for a couple days. Normally, I just turn them on.
any ideas? the units seem to be functioning (I know the HT is receiving aprs signals, and looks to be set correctly in the menus) (8GR)
Old 04-07-2014, 03:45 PM
Have you changed your call sign or is it still KD0MZE? Your last aprs.fi location is from 11/25/2013. Plus all they have is a KD0MZE and KD0MZE-7, don't see a -9 or anything. I just sent a position from my truck a few minutes ago and it showed up on aprs.fi so the system seems to be working.
Old 04-07-2014, 03:51 PM
Default nope still the same
I've got KD0MZE for my main mobile (fj60) and the HT is registered as "-7" the sites seem to be working well as I can find others. Is there a location online to check things out? maybe email to Byonics?
Old 04-07-2014, 03:57 PM
You probably should do some troubleshooting before asking Byon for help. What are you going to ask him?
When you transmit a packet do you see/hear anything happen immediately after? You will need to be able to hit a digipeater for your packet to find an I-GATE to the Internet. There's only a couple of gateways to the Internet locally and not many more digital repeaters to re-transmit your packet, so it's not automatic that you'll have a path to aprs.fi.
Have you tried driving around to see if you're just not hitting any of them?
Old 04-07-2014, 04:27 PM
Default so...I thought so...but...
I thought I did today, but ...forgot to plug it in. My HT for sure isn't hitting a digipeater from my back yard, whereas, I have in the past. I'll do a little more testing. Like that last ping on "-7"...I thought I was tracking us the whole way. I only got out that one time over 8hours.
Old 04-07-2014, 10:47 PM
Default hmmm...
well...had it on from about 5:15 to 5:45 - not long, I know. but was in Boulder. could have been hard to get to a digipeater. I'll try a different antenna, next.
Old 04-08-2014, 07:53 AM
So what exactly are we talking about here? You mention a VX8R and a Tinytrak3. You don't need a TNC with a VX8R. So do neither of your APRS trackers work? That seems very odd if so. Please list the hardware you're trying to get working. If neither is working then I would suspect a location issue is likely, more power, higher location, etc. Has anyone else been to your location and experience no issues?
You should get at least a couple of position reports showing up in 30 minutes. If your location does not change for a few minutes sometimes aprs.fi doesn't update, but it should for what you were doing. Now if you are in Boulder sometimes you don't have a good aspect to a digipeater, it's kind of an RF black hole in town.
You could try an external antenna or a new location, maybe drive east a few miles, but there might be more going on here. Check cables, make sure they're mated and not broken. Probably in a configuration some place, hard to say. If you're hearing other stations that's a good indication it's likely not an RF issue, e.g. antenna, RF sections. Next step is to make sure you are decoding them, that they are showing up in heard stations, etc. This is where you need to understand modems. You might break squelch but if the header or tail are clipped the packet won't decode, if the levels are too high or low the modem can't figure out where bits start and stop, etc.
If you're using a VX8R the default settings are usually sufficient to get you on the air, just add your call sign. I have customized my FTM-350 to some extent, mostly tweaking the path settings. If want to dump the APRS and digital settings I can take a look. The TT3 I think has a pot you use to set the levels inside but if it's like my TT4 it doesn't have a lot of effect. I will assume since you had it working at one time that you have the correct PTT and signal jumpers (sometimes HTs share functions on connector pins to there might be a jumper you set to make it compatible with mobiles or HTs).
There are delays built into APRS configurations that can cause odd issues like this. You can set the time slot for example, which is to prevent on-air packet collisions. There are other settings that I'll have to think about. The user's manual should explain all these, though. You can set the number of hops a packet is allowed to take, which if it's set too low you don't get enough retransmissions and set too high you get frozen out because it looks like you're flooding the system. You generally don't need more than 2 hops in town and even in Moab that should be enough to make an I-GATE.
Old 04-08-2014, 08:21 AM
Default exactly. neither seem to be getting out.
correct. neither are working. I've got the vx-8gr and the all-in-one RTG setup from Byonics. should be "ready-to-go", as they say. i'm pretty confident I have the 8GR set up correctly (GPS on, SSID as "-7", APRS modem to 1200, beacon to auto/every 10min) and I am receiving APRS stations on the 8GR. Can I test one SSID on my HT? (LIke, turn on the RTG and watch the HT for ping?) OR does that confuse the system?
Both used to work just fine. It could be the Boulder thing and, I usually hit a hole near the I25/36 interchange.
. . I'll be doing another test on the way in from Lafayette to Denver today and, I've got another hershey kiss antenna to test today on the way home.
Old 04-08-2014, 10:08 AM
Default well...seems to be working...but only OK.
looks like there's a bigger shadow for digipeaters in Boulder County than I figured. looks like I pinged a bit on the way in today. I'll test the 8GR on the way home.
Old 04-08-2014, 11:22 AM
You can transmit with one radio and see stations show up on the other, that's fine. APRS stations themselves don't care one way or the other, it's aprs.fi that digests the reports and sometimes ignores updates. Also digipeaters will sometimes not repeat packets that are transmitted too close in time, but that's fairly rare and you'd have to be flooding the system with transmissions back-to-back.
If both are acting up them I would expect location. Either interference, no close digipeaters, etc. Not all repeater sites have digital repeaters, actually a small percentage actually are APRS repeaters since they would be a second radio and antenna separate from the main repeater. Also there are only a couple that are also gateways to the Internet. I want to say maybe one or two I-GATES exist in Denver/Boulder/Ft. Collins. Except for I-GATEs most digipeaters are not co-located on commercial sites but are usually just hams with a tower at their house, so coverages is a lot worse than you're used to.
A ham can set up a digipeater without coordinating with anyone since they are store-and-forward rather than input/output offset so the network changes all the time. You might have a digipeater running one day and gone the next. Other times they are mobile or portable and only last a few minutes or hours. An APRS digipeater listens on 144.390 for a packet, stores it temporarily and then retransmits on 144.390 some short time later after the original radio has unkeyed. You will hear your packet being retransmitted after your radio switches from TX to RX and your VX-8R will usually then show your station in the list. If it does not then your packet is not being retransmitted for whatever reason.
