Old 04-15-2014, 06:49 PM
Default Zipper Repair
I did a search and came up empty. The zipper on the main door of my tent needs to be replaced. Does anyone have any recommendations of a Denver area repair shop? I need this done before Moab, otherwise I need to buy a new tent, and the rest of this tent is just fine.
Old 04-15-2014, 07:04 PM
Seldom Seen's Avatar
Stichlines
Old 04-15-2014, 07:10 PM
Squishy!'s Avatar
Squishy! Squishy! is offline
X2 they're good. Right near A&A exhaust.
-Justin Morgan,
TLCA #23166
"Apollo"-1988 Hilux, 1999 3.4L, Supercharged, 2.1" URD pulley, URD 7th injector, 2 1/2" Magnaflow exhaust, SOLD
"RedChili"-1987 Super Beast
Old 04-15-2014, 07:28 PM
Phyllis @ Stitchlines = goodness
She usually charges by the inch for zippers, or at least that was the way she used to do it. Don't hesitate though, get it in there ASAP, her lead times can be pretty long.
Old 04-15-2014, 07:49 PM
Just a block or so down Broadway there is a shop that Phyllis sent me to for window and zipper replacement on my Paki top. Phyllis was really back logged. Good work and reasonably priced.
Old 04-15-2014, 09:00 PM
Thanks guys! I'll call first thing in the morning. Between tax prep and Cruise Moab trail assignments and leader/gunner stuff this has been as busy a week as I expected! Thank goodness packet stuff has been put off by a week ;P
Old 04-15-2014, 09:04 PM
L43dean L43dean is offline
Jeff, Do the zipper teeth pull apart after you pull the zipper pull shut. If this is the case and you have a "YKK" style coil tooth zipper, it is often that the PULL is wearing. The height dimension inside the pull has worn to become too big. This metal pull can be gently squeezed, at the back end or following end, with pliers. Put your plier jaws behind the pull tab on the zipper pull with the pull still on the zipper teeth. Squeeze very gently a little at a time and test. I've worked in a couple mountaineering shops and more times than not I could get a few more weeks of use from the zip on customers gear, our rental gear and my own. Eventually the zipper needs a new pull or complete re-placement. Good luck. Or maybe now is the time for a Springbar, OZ or Bibler!
Old 04-15-2014, 09:12 PM
Default PakTop hi-jack
Thanks Ricardo! I need to have two small patches sewn on my canvas top. I want to hire someone who has a commercial machine for thick canvas.
Old 04-15-2014, 09:23 PM
Originally Posted by L43dean View Post
Jeff, Do the zipper teeth pull apart after you pull the zipper pull shut. If this is the case and you have a "YKK" style coil tooth zipper, it is often that the PULL is wearing...
Good catch....This is another option.
Old 04-15-2014, 10:38 PM
I could have sold many hundreds of those in the eighties,"Eighties" a good Killing Joke tune. We used to stock all the sizes and types of pulls and stops I could get.
