Old 08-31-2014, 08:53 PM
Romer's Avatar
Romer Romer is offline
Default Power steering problem or something binding?
The Romer Caravan (Rachel, Sarah and I) took our 3 trucks to Red Cone. Going up Red Cone a Jeep was coming down and pulled over, I went through some harry rocks to get around him and heard a thud on the passenger side.
After that my steering felt like crap. It would jump, Turns to the passenger side were hard and I had to make 3 point turns were I shouldn't have.
Looked underneath and nothing looked bent or broken.
Drove OK on the highway, was less power in turns and more manual.
Making the turn into my garage took several efforts feeling like a poor manual steering at 1 MPH. In other words at speed it does better, less pressure I assume.
No loss of Power Steering fluid
No shimy or noise on the highway. Did 70 MPH on the highway and it stayed in track
Thinking it has to be something on the passenger side as that's where I heard a thud (Rock hit I assume) and that's the direction turning is harder
With one tire jacked up and the other on the ground, how much slip should there be on the one in the air tuning it by hand for IFS? Mine only moves a couple of inches and then locks, no matter which tire is in the air
Power steering seems normal with one tire in the air and turning the steering wheel obviously standing still. Doesn't matter which tire is in the air, wheel turns easy
Put both tires down and I can't really turn the wheel in the same setup.
Any thoughts?
Ken Romer - K0ROM
14 URJ200
77 FJ40
16 RX450
16 Kimberley Karavan
Old 09-01-2014, 12:03 AM
Is this the red one or the white one?
Old 09-01-2014, 08:05 AM
Romer's Avatar
sorry, its the 100 series. The red one is getting Fuel injection installed
Ken Romer - K0ROM
14 URJ200
77 FJ40
16 RX450
Old 09-01-2014, 11:12 AM
Romer's Avatar
Belt seems tight, haven't lost any fluid.
Seems there is some fluid, but not significant where the steering wheel assembly ties into the rack
Much harder to turn driver when going slow. Put it in neutral and revved engine and didn't make a difference
I would think Pump except I can't see how it would make one side harder than the other
When going slow and turning Driver hear air escaping sound (Best way to describe), don't hear same sound when turning passenger, maybe air control valve? but can't see why turning passenger is much harder
Ken Romer - K0ROM
14 URJ200
77 FJ40
16 RX450
Old 09-01-2014, 12:30 PM
Romer's Avatar
Talked to Robbie. He agrees its probably my rack based on what I told him
Ken Romer - K0ROM
14 URJ200
77 FJ40
16 RX450
Old 09-02-2014, 08:13 PM
I was going to say the rack but looks like Robbie beat me to it.
Old 09-03-2014, 09:02 AM
Romer's Avatar
To update, the shop said the pump isn't working well and they think that is the cause of the problem. Since the rack is weeping, I told them to replace both. I should have a good steering system when I get it back
Ken Romer - K0ROM
14 URJ200
77 FJ40
16 RX450
Old 09-03-2014, 11:28 AM
AxleIke's Avatar
AxleIke AxleIke is offline
They are putting in OEM yes? I don't know if its a mini truck thing or not, but on 4runners and tacos, non OEM steering, ball joints, tie rods, etc... are garbage.
Good luck with the repair!
Isaac
Generation Dead
Old 09-03-2014, 11:50 AM
Romer's Avatar
Yes Toyota parts only
Ken Romer - K0ROM
14 URJ200
77 FJ40
16 RX450
Old 09-03-2014, 01:47 PM
AxleIke's Avatar
Good. Should be good as new then!
Isaac
Generation Dead
