Old 05-12-2014, 02:34 PM
baja1d's Avatar
baja1d baja1d is offline
Default Wanted: 1FZE Enigine- FJ80
Looks like CM2014 may have put the "Green Bean's" engine over the edge. I'm still driving it daily but adding about 1qt of oil every 400 miles. It's got 260k on the clock and at $10,000 to rebuild I'd like to source a donor. Anyone have one that they may not use? Oleg's got one but he may use it on a build... keeping my fingures crossed at this point!
Travis Hurley– Owner/ C.E.O.
Old 05-12-2014, 03:10 PM
simps80's Avatar
simps80 simps80 is offline
i think Cristo had a few might call slee
Mike | KØSMP |
Old 05-12-2014, 05:26 PM
baja1d's Avatar
Tried, he doesn't have any
Old 05-12-2014, 06:19 PM
Squishy!'s Avatar
Squishy! Squishy! is offline
Yota Jim had a couple 80 series
-Justin Morgan,
TLCA #23166
"RedChili"-1987 Super Beast
Old 05-12-2014, 06:47 PM
In todays market you should be able to get a complete running parts truck for a couple grand. Probably not the number your looking for but at $10K for a full rebuild....
Problem is that most get to parts status due to the engine.
If you think it a head problem scroll down the page to Daniel's listing
Old 05-12-2014, 07:15 PM
baja1d's Avatar
I had that same thought. Looked for some "unlocked" ones today but it's slim pickens.
I think it maybe rings. Coolant looks good & just little puffs of smoke when accelerating
Old 05-12-2014, 07:58 PM
Inukshuk's Avatar
Inukshuk Inukshuk is offline
I'd put in a V8 if I had to do it all over again. Similar cost, more power and better mileage. But, in theory, you will be able to score a decent used engine and do the swap yourself.
What points to rings?
Daniel Markofsky - Daniel@Markofsky.com KØFZJ
Old 05-12-2014, 08:07 PM
baja1d's Avatar
Also considered but I really wanted this to be a simple swap versus fabrication, etcetera. Just the smoke and quart of oil every 400 miles but I really haven't had a chance to investigate it much
Old 05-12-2014, 11:36 PM
Tuckytres's Avatar
Tuckytres Tuckytres is offline
Event Coordinator
Default v8
How about a 4.7 out of a 2007 Sequoia with 5 speed? 51k on it.
Old 05-13-2014, 12:03 AM
baja1d's Avatar
That may work... You got one?
HTML code is On
