Old 05-20-2014, 08:36 AM
aprosise's Avatar
aprosise aprosise is offline
Default Rear axle purging gear oil
Hopefully somebody has some insight on this...
I won a Nitro Offroad Diff cover for my 60 series at Cruise Moab, I put it on when I got back and refilled my rear axle with the appropriate amount of oil, just below the fill hole...or so I thought.
Now, it's purging gear oil out of the breather. A good amount, enough to wet the whole right leaf and bottom of the gas tank. Ive pull the breather tube off and cleaned it and checked function. All seems fine there.
Any ideas?
Old 05-20-2014, 01:36 PM
BritKLR BritKLR is offline
When I first got my 60 and drained and refilled the rear diff it did the exact same thing. The only thing I concluded was I didn't wait long enough, once filled, for the slight extra fluid I filled to drain out. Maybe I had less then an ounce extra in it, but boy did it gush like a fire hose out of the breather once it got heated. So, you may have just slightly too much fluid in it.
Good luck!
Paul Carrill
Adventure Tool Company LLC
www.adventuretoolcompany.com
TLCA#22379
"Like" us on Facebook:
https://www.facebook.com/AdventureToolCompany
Old 05-20-2014, 02:04 PM
LXBRADY's Avatar
LXBRADY LXBRADY is offline
Sounds like its puking excess oil.
Steve Brady
TLCA # 19524
KD0JVZ
97 LX450
Old 05-20-2014, 03:44 PM
The vent is on the top of the axle tube. It would take a lot of extra oil to raise the level up to the vent tube - way more than you could squirt in the fill hole. Any chance the truck was parked at a pretty severe side angle that may have made the level high on the downhill side of the axle?
Old 05-21-2014, 10:57 AM
aprosise's Avatar
The axle was filled on level ground, and I did not fill it until is overflowed. Per the shop manual, I filled until oil was slightly below the fill hole, but not overflowing. Im guessing with the new diff cover I have more oil capacity, but that shouldn't make it overflow.
Ill keep an eye on it my levels. I know its full so I shouldn't be worried about starving it at least.
Old 05-21-2014, 12:17 PM
AimCOTaco's Avatar
AimCOTaco AimCOTaco is offline
Vice Commander
Probably is just adjusting it's self. I occasionally see the same thing. The vent is on top but of course the oil is slung when running so it can definitely be expelled at the vent.
Andy | Longmont | TLCA#22354
Follow CRUISE MOAB on Facebook
-1999 UZJ100 -Black, Ever Evolving, now with SLEE SHOCKS!!
-2001 Tacoma 2.7L Reg Cab 4x4 -Silver,my DD/all purpose truck, mild build so far.
-Kilo-Delta-Zero-Tango-Quebec-Tango-
