Old 05-26-2014, 08:48 PM
Lars's Avatar
Lars Lars is offline
Administrator
Default Hazed Headlights
I took some time today to polish up the 06 4runner and noticed that the headlights are starting to get a haze on them. I assume oxidation. any good experience out there with getting them clear again?
-James Simpson 15 4runner -KD0LAR
Old 05-26-2014, 09:42 PM
TheHoneyBadger's Avatar
I'd like to know the same thing. My head lights are very hazy.
Products? Tips?
Travis R.
TLCA #22468
I would rather walk than drive anything that's 2WD.
Old 05-26-2014, 09:54 PM
I can tell you most of the fixes don't last and the haziness comes back. I used the 3M product on my wife's car a few times before I sold it, and it looks great at first, but the haze quickly comes back after a few weeks/months.
Old 05-26-2014, 10:07 PM
coloradobound's Avatar
coloradobound coloradobound is offline
I've used vinegar to get a good bit of the haze out, then a scratch doctor of polish thats a bit more aggressive go get more of it out and to protect them again. Had pretty good results and has lasted a good amount of time.
2002 Tacoma DCab TRD, OME suspension, 1" Daystar Bodylift, ARB front bumper, Lightforce 170's, 20" led light bar, blacked out HID bixenon projectors, Slee Sliders, 33" Yoko's on 5th gen 4Runner wheels, TRD supercharger, exhaust, and trans cooler.
to do: snorkel, ditch lights on Cbioffroadfab brackets, flush mount lights in new rear bumper, rock lights, new retrofits in headlights, ARB fridge mounts in bed w power, hids in LightForce (or arb led knockoffs)
Old 05-27-2014, 01:26 PM
I have done 8? cars with 2000 grit (or very fine) compound and a buffer. It gets them 95% clear. I guess I can't say that I've owned one long enough after that to see if they got hazy again (or the vehicle was a garage queen and didn't see much light).
If you use a buffer, protect all surrounding areas with a couple layers of masking or duct tape so you don't fry any other paintwork. Removing the headlight housing and putting it gently in a padded vise is best.
Old 05-27-2014, 01:41 PM
3M kit with the sandpaper and buffing wheels. Lasted about 3 years on my Tundra.
http://risingsun4x4club.org/forum2/s...llow+headlight
Old 05-27-2014, 02:31 PM
Sanding and polishing the lenses will make them clear but without a quality UV portection, they will cloud up again. I tried some other cheaper kits that were garbage. This one is holding pretty wwll two years later:
http://www.bgprod.com/bg-headlight-r...r-bgprod-page/
Old 05-27-2014, 03:03 PM
Tacomedic Tacomedic is offline
x2 on this. Used this product on both my Tacoma and 4Runner... both vehicles purchased with 100k+ on them and very hazed headlights. Cleaned them up like new and has stayed that way for 50k.
2004 Tacoma X-Cab TRD, 4WD, Auto, OME & 33's
2004 4Runner Limited V8
1974 FJ40, Mid Frame-Off Restoration
Old 05-28-2014, 01:31 AM
I used the "Mother's" headlight restoration kit on the Subaru a few months ago. Worked great any took less than an hour. They still look good and the beam pattern/cut off are back. The lights were approaching trash status before. So even if I need to do this every 6 months so be it. Better than 100's on new assemblies.
Old 05-28-2014, 09:13 AM
Griot's Garage is what I've seen work the best. Haven't tried the 3M.
