Old 05-27-2014, 03:43 PM
AddictedOffroad's Avatar
AddictedOffroad AddictedOffroad is offline
Default Crawler parts, motors, tcases. Cleaning shop
**** High Pinion Elocked 3rd. I will set this up with new 5.29s, solid spacer, and master install kit. Includes actuator, but no harness. $900
**** 4.7 23sp gear set for gear driven Tcase. I can include the Tcase for $600 total, or build it for another $200.
**** set of 79-85 Dirty 30 axle shafts. inners and outer 30 spline shafts. New Never run shafts and I will warranty them if you ever break them. $500
****2x forward shift gear driven Tcases $75/ea
****2x top shift tcases $150/ea
****97' 3.4L motor. 177K. Harness included for A/T. No ECU. No Alt, No starter, No a/c compressor. Pulled from wrecked Tacoma. $500
****98' 3.4L Motor. 213K. New timing belt and pulleys just installed. Harness included, ECU included, NO Alt, No A/C compressor. Auto tranny. No Tcase. Motor was pulled from rolled 4runner. $800
970-420-4198
Scotty
Old 06-14-2014, 01:19 PM
Squishy!'s Avatar
Squishy! Squishy! is offline
Pm'd
-Justin Morgan,
TLCA #23166
"RedChili"-1987 Super Beast
HTML code is On
