Old 06-16-2014, 05:05 PM
CardinalFJ60's Avatar
Default my new(to me) KTM is too tall - do I need a low seat??
so...my KTM is too tall. I feel like a little kid swinging my legs in a chair that's too big.
I'm about 5'7" on a good day, and I know I can adjust the suspension to some degree - for which I'll get some assistance...BUT...my question is, being as short as I am, should I look for a 'low' seat? it's not much lower (.5"?)
Old 06-16-2014, 05:37 PM
yes.
Old 06-16-2014, 05:47 PM
Default thanks.
thanks, that's what I figured.
Old 06-16-2014, 06:00 PM
MTSN's Avatar
MTSN MTSN is offline
I would definitely shave the seat down and maybe even have a lowering link and forks shortened professionally. I'm even shorter than you and have a CRF250X that I've done the above to and it's made a ton of difference. I went to Hitchcock Industries and Neil there did the work the right way - the wrong way is to just lower the forks in the triple clamps because the tire can make contact with the fender and all sorts of other not great things when you bottom out. You might lose an inch or two of travel but if it means you can enjoy the bike it's worth it.
Current: 2017 Tacoma, 2008 200 series
Former: 2014 200 series, 1998 100 series
TLCA# 22666
Old 06-18-2014, 11:15 AM
TheHoneyBadger's Avatar
You should definitely grow longer legs. Just saying.
Travis R.
TLCA #22468
I would rather walk than drive anything that's 2WD.
Old 06-18-2014, 11:58 AM
Just need new riding boots.
Old 06-18-2014, 01:41 PM
LARGEONE's Avatar
LARGEONE LARGEONE is offline
No...you need to give it to me Will it fit 6'-3"?
Just kidding...you are on the right track!
Paul
KE0OLZ
1967 FJ40 - Nearly Stock
http://www.vrbo.com/322094
Old 06-18-2014, 02:43 PM
Default Awesome!
Old 06-18-2014, 02:44 PM
Default Enduro Engineering
I think I'm going to get an EE super soft seat - it should give me about 3/4".
Old 06-18-2014, 03:00 PM
I'd start there, and then ride it for a bit and just see what you think you need at that point. The next step would probably be a full suspension tune with softer and maybe shorter springs. The manual has some good documentation on spring settings based on weight, but you might need someone like Hitchcock to set you up optimally with your height and weight.
