Old 07-10-2014, 08:50 AM
rckhound's Avatar
rckhound rckhound is offline
Travis I have a 4spd you can have uf the others fall through.
1965 FJ45 LPB
1995 FZJ80 Lifted, Locked, Geared, and Built
1984 FJ60 Stock and Staying That Way
Sold1979/83 Fj40, 1987 Fj60, 2006 TRD Taco.
TLCA#22362
A nation that destroys its soil destroys itself-FDR
Old 07-10-2014, 09:06 AM
baja1d's Avatar
baja1d baja1d is offline
Right on, thanks guys. I think that I may actually need a 40 series tranny. IIRC, the 60 series trannys have a spacer on the rear so that an H55 can be swapped in lieu of.
Travis Hurley– Owner/ C.E.O.
Old 07-10-2014, 03:23 PM
later model did ...early didn't
Old 07-10-2014, 07:51 PM
I think it was somewhere in 85 when the change happened.
Old 07-10-2014, 08:54 PM
I need to open up the box and take a look at it. I honestly don't know if it's an early or late model.
Old 07-21-2014, 07:18 PM
Ok, Robbie stopped by today and looked at the FJ60 Trans. It's a late model with the spacer. He said it had good splines. This is not the ideal candidate to put into a 40 since you'll have to modify the frame cross member to fit it and shorten the rear drive line substantially.
Let me know if you still want it. If so, I need it gone ASAP. THANKS!
Old 07-21-2014, 07:36 PM
baja1d's Avatar
I'll grab it just in case someone needs it in the future. Steve had a 40 series tranny that I picked up & shipped with the 40 to Oregon
Old 07-21-2014, 09:12 PM
OK, when can you get it? I have to have my stuff outa here soon.
Old 07-21-2014, 09:30 PM
baja1d's Avatar
Sent a PM
Old 07-23-2014, 06:32 AM
cruiseroutfit's Avatar
cruiseroutfit cruiseroutfit is offline
Wasatch Cruisers
What t-case are you planning to run behind the 4spd? Keep in mind there are two output versions of the 4 speed, 16 spline and 19 spline.
Kurt Williams
Cruiser Outfitters
Your original outfitter for OME - ARB - AA - Safari - Helton - Engel - Since 1992
Please call or email for pricing, tech, stock check, etc
Join us on Facebook
