Old 07-27-2014, 12:03 AM
Romer Romer is offline
We have two 100's, both with OME 2.5" heavy lift and no issues
MTSN was talking about rake, not lift and that you should adjust it(Torsion bars) so it sits lower in the front than the back
Old 07-27-2014, 12:24 AM
Ali FJ80's Avatar
Ali FJ80 Ali FJ80 is offline
that is actually the lift I would like to go with eventually.
was also talking about the rake, I don't want to eliminate it completely as I know its needed. I wanted to make it just a little less raked than it appears to be at the moment while I have the stock suspension. I figured if I can lift the front half an inch or so using the torsion bars without causing any issues it would work for a little while.
However I have no first hand knowledge on this just what I have been reading on MUD so if you guys think this is bad idea for any reason please do let me know. thanks.
MKIV Supra TT
LX570
S4 avant
Old 07-27-2014, 03:07 PM
Ali FJ80's Avatar
got rid of running boards and whited out belt line trim this morning.
MKIV Supra TT
LX570
S4 avant
Old 07-27-2014, 10:04 PM
nakman nakman is online now
Looking good! I've got the white belt line too..
Though I saw a white 100 that did black from the beltline down and thought it looked really sharp. I also like how you did your emblems, I need to do that as mine are still goldish.
Old 07-27-2014, 10:17 PM
OilHammer's Avatar
Nice! I'll swing over later this week and park next to you so you can get a feel for the OME lift and one size larger tires. I'm not really fond of the OME shocks unless you plan to run a good bit of extra weight, but the ride stance looks much better slightly lifted in my opinion.
1966 FJ45 lwb stock
2003 100 OME lift
KD0PZL
Old 07-27-2014, 11:47 PM
Ali FJ80's Avatar
your 100 looks sweet! exactly what I want to get to eventually. I saw the one that did black from the beltline down a few weeks back or so and cannot find it again but it did look good. Emblems turned out pretty good considering how easy they were to do. really made a difference.
cool, it will be good to compare. I slapped on some tundra rims with 275/65/18's this evening which gives it a little more height.
MKIV Supra TT
LX570
S4 avant
Old 07-28-2014, 10:48 PM
Ali FJ80's Avatar
gave the stereo an upgrade. really makes the interior look younger.
MKIV Supra TT
LX570
S4 avant
Old 03-09-2015, 11:32 AM
Ali FJ80's Avatar
been a while since I updated this, as she sit now after tossing on some MAF 30mm spacers yesterday and adjusting the front. Thanks Barry for the suggestion on using spacers, the ride is very smooth and not bouncy at all.
MKIV Supra TT
LX570
S4 avant
Old 03-09-2015, 11:38 AM
MTSN's Avatar
MTSN MTSN is offline
^ Wow nice job!
Current: 2017 Tacoma, 2008 200 series
Former: 2014 200 series, 1998 100 series
TLCA# 22666
Old 03-09-2015, 12:04 PM
Ali FJ80's Avatar
Thanks Matt, its coming together slowly. Am still on the fence but was thinking of contacting you regarding the spacers you had listed.
MKIV Supra TT
LX570
S4 avant
