Old 08-03-2014, 09:24 AM
girraffe girraffe is offline
Default Free parts
Free. The 40 parts are from a 78. Turn switch from fj55 and aluminum step pad is from a 80 series. Call or text me for an address. 303 five two six 8411
Old 08-03-2014, 09:43 AM
Goes in the trash on Tuesday if no one wants it
Old 08-03-2014, 11:48 AM
gr8fulabe's Avatar
Would the turn signal switch fit on a 74 40, or are they pig specific? Any idea?
Thanks
Abe
Old 08-03-2014, 07:31 PM
No idea. It's free though so it's not like you would be out a ton of money if it didn't work...
Old 08-03-2014, 08:17 PM
DanS's Avatar
DanS DanS is offline
Thanks
Abe
Should fit no problem.
The major difference between a 40 and 55 column is length, and the end that connects to the steering box. The 40 has a rag joint, and the 55 has a splined shaft that connects to a U-joint.
Dan
Old 08-04-2014, 10:06 AM
FYI - That bell housing is critical for putting a later 2F in an older truck. FJ60 bell housings aren't as useful. Wish I wasn't sitting on several FJ60 bell housings at this time, but someone may want to snag it. It even has the engine mounts attached.
Old 08-04-2014, 01:39 PM
gr8fulabe's Avatar
Cool I'll take the turn signal from you if you don't mind! I'd also be happy to pick up parts for others too if anyone wants anything. I'm planning to hopefully go to the meeting this week, as well as the rally & 40's only run too if it is all possible, so plenty of chances to get parts to people if you want them.
thanks,
Abe
HTML code is On
