Old 08-11-2014, 01:52 PM
MTSN's Avatar
MTSN MTSN is offline
Default Where to buy square headed bolts?
I bought an awning from CVT which unfortunately didn't come with mounting bolts and nuts. It takes a square bolt to slide into the back side of the awning to mount it to the brackets, and I've been looking all over town for the bolts with no luck. I found a couple at Ace Hardware, but they were slightly too big. I'm looking for a 3/16" head square head bolt - any ideas on where to pick up something like that? I've tried Lowe's, Home Depot, and Ace so far...
Current: 2017 Tacoma, 2008 200 series
Former: 2014 200 series, 1998 100 series
TLCA# 22666
Old 08-11-2014, 02:02 PM
McMaster.com
Old 08-11-2014, 03:26 PM
MTSN's Avatar
That's a great site, but I actually don't see any that are small enough to fit my application Is there anywhere local I can drop in and look around? I have it in the back of my truck to make it easy to try out different bolt sizes!
TLCA# 22666
Old 08-11-2014, 03:33 PM
Seldom Seen's Avatar
AAA Trading Post on B'way
Old 08-11-2014, 04:03 PM
locally, dunno there is http://www.aaametric.com/ you could ask them. They sell standard too.
stanley doesn't list them but you can ask who might have them http://www.stanleyfasteners.com/
or call CVT and ask to buy the bolts they supply.
Amazon, google has lots
Old 08-11-2014, 04:41 PM
TheHoneyBadger's Avatar
A Fastenal store might have it. Might even have it in Grade 8.
Travis R.
TLCA #22468
I would rather walk than drive anything that's 2WD.
Old 08-11-2014, 05:07 PM
x2 on A&A Tradin' Post
You might call them to be sure though.
Old 08-11-2014, 07:00 PM
Woops. A&A
Old 08-14-2014, 11:32 PM
Matt, did you find any? I picked up a new awning and it's only got bolts for 2 mounts, and of course I want to run 3... I may run to Fastenal at lunch tomorrow, will snag a few extra if they have some.
Old 08-15-2014, 12:02 PM
AimCOTaco's Avatar
AimCOTaco AimCOTaco is offline
Vice Commander
Guys, my ARB accepts a standard head M4 bolt with a 10mm hex head. (in the T-slots for mounting)
Are you sure a square head is required?
Andy | Longmont | TLCA#22354
Follow CRUISE MOAB on Facebook
-1999 UZJ100 -Black, Ever Evolving, now with SLEE SHOCKS!!
-2001 Tacoma 2.7L Reg Cab 4x4 -Silver,my DD/all purpose truck, mild build so far.
-Kilo-Delta-Zero-Tango-Quebec-Tango-
