Old 08-15-2014, 02:21 PM
Pffft. ARB...
Old 08-15-2014, 02:23 PM
Matt, I picked up some 5/16-18 square nuts that are the same size as those bolt heads. I also snagged bolts, washers, and lock washers- the nuts are zinc but everything else is 18-8 stainless
You going to make the rally? I can bring some down... wait, I thought you sold your 100 to buy another bike?
Old 08-15-2014, 03:44 PM
AimCOTaco's Avatar
AimCOTaco AimCOTaco is offline
Vice Commander
Pffft. ARB...
Nice! Glad you got your square nuts located
Andy | Longmont | TLCA#22354
Follow CRUISE MOAB on Facebook
-1999 UZJ100 -Black, Ever Evolving, now with SLEE SHOCKS!!
-2001 Tacoma 2.7L Reg Cab 4x4 -Silver,my DD/all purpose truck, mild build so far.
-Kilo-Delta-Zero-Tango-Quebec-Tango-
Old 08-17-2014, 10:56 PM
Well dad gum.. my square nuts are just a little bit too wide to fit into the extrusion. I could grind them, but I need this to be as bolt & go as possible, as I'm working on a new product solution here and "grind down nuts" isn't going to make the final BOM.
I did find that a 5/16-18 bolt, which uses a 1/2" wrench, will slide right in and grab pretty well, and it should hold just fine but I am going to hold out for more surface area and get some square ones. I'm going back to Fastenal tomorrow to see if they can special order some.
Old 08-19-2014, 09:09 AM
Mcguckins has them in boulder, so do most ace hardware a but the selection isn't as good.
