Old 08-15-2014, 09:40 PM
baja1d's Avatar
baja1d baja1d is offline
Default FJ60 transmission
I've got three questions for the Gurus:
1. Did pre-85 FJ60 4-speed transmissions come with a 10 spline count input & output shafts? If so, see number two...
2. Anyone got a good one laying around that they want sell? If yes... Please call me. If not, see number 3...
3. Where can I get a rebuild kit?
The syncros went out in my Dad's 40; hence the shifting problems I had in Ouray.
Travis Hurley– Owner/ C.E.O.
Old 08-15-2014, 09:50 PM
rckhound's Avatar
rckhound rckhound is offline
What happened with the one I gave you?
1965 FJ45 LPB
1995 FZJ80 Lifted, Locked, Geared, and Built
1984 FJ60 Stock and Staying That Way
Sold1979/83 Fj40, 1987 Fj60, 2006 TRD Taco.
TLCA#22362
A nation that destroys its soil destroys itself-FDR
Old 08-15-2014, 09:56 PM
baja1d's Avatar
I shipped it with the 40 but it has a 19 spline output shaft. The Marlin Crawl Box requires a 10 spline output.
Old 08-15-2014, 10:10 PM
baja1d's Avatar
The big question is if the current transmission's rear output is stock or was it changed out when the crawl box was added... This was all PO modifications
Old 08-20-2014, 01:00 AM
IIRC the 10 spline is a 3 speed output and 19 is a 4/5 speed output. Also IIRC, all F and H series are 10 spline input.
Old 08-20-2014, 08:02 AM
baja1d's Avatar
Me too, however, I spoke with the PO & he's claiming that it's a stock 1985 FJ60 transmission?
Old 08-20-2014, 09:35 PM
No way 10 spline output is stock on a 4 speed. Even non-USA. Either the PO is mistaken, or the output shaft was replaced with some kind of non-stock part.
Old 08-22-2014, 06:33 PM
nattybumppo's Avatar
I have a 4-speed from my old 1987 fj60 that worked great. I put in a 5-speed, so this has been taking up floor space in my garage. Let me know if it would work for you and we can talk about a price that works for you.
Sascha Steinway TLCA # 20217
2013 F-150 "Black Ops"
