Old 08-27-2014, 08:32 AM
baja1d's Avatar
baja1d baja1d is offline
Default Body mounts anyone?
Read up on this a bit & finally did it. My 1st gen 4-runner is mounted on a pickup frame & whoever did the swap did a pretty hack job. Buying a body mount kit wasn't an option due to mismatched frame & body. In the end, the 4 mounts were less than $50.
And the end result:
Travis Hurley– Owner/ C.E.O.
Old 08-27-2014, 01:01 PM
simps80's Avatar
simps80 simps80 is offline
dang nice work !
Mike | KØSMP |
1997 fzj80 | 1976 FJ40 | TLCA # 20038
Old 08-28-2014, 09:46 AM
Nice work on the welded washers. Did you weld in your flip flops, per the photo? ;-)
Old 08-28-2014, 10:56 AM
baja1d's Avatar
Of course (good eye, I had to look back through those photos)...they're the new OSHA approved style!
Old 08-28-2014, 02:37 PM
As long as they are the OSHA-approve 'low toxic smoke' flip flops, then I'm ok with it. ;-)
On a hot summer day, sometimes I look at my welding garb and realize that it does not exactly offer full coverage.
