Old 10-09-2006, 02:32 PM
FJBen's Avatar
FJBen FJBen is offline
I understand the physics behind it, and needing negative pull to keep the rig more stable, I just don't think I'll have to worry about it up front at all until I do something custom, it won't useat up front.
The rear yeah, I would like that extra pull to be there. It can still only force that front suspension so much without having to do something different up there.
I have no sway bars and I also pull that front pin occasionlly during wheeling so she actually is pretty dang balanced.
Guess bottom line I will retain the rear and be happy !
TLCA#15530
96 285's OME 's ride
Old 10-10-2006, 10:05 AM
FJBen's Avatar
UPDATE:
Be very careful when measuring lengths and such. I *might* have to move those top mounts inwards by re-drilling the top hole as the shock body can possibly come into contact on full stuff. I'm doing the panhards this week so that may fix the issue on the rear.
TLCA#15530
Old 10-10-2006, 10:15 AM
Beater's Avatar
Beater Beater is offline
be sure to check aa-mfg for adjustable mounts that might work for you.
  #24
Old 10-10-2006, 12:35 PM
FJBen's Avatar
lol, thanks for the heads up on that one! I doubt they'll have custom upper mounts that will work with the 80 series upper rear, but hey, you never know.
I just need to redrill that upper mount inwards more...one of those trial/error thingies...
TLCA#15530
  #25
Old 10-18-2006, 03:58 PM
FJBen's Avatar
Moved the mount inwards a little and all is good. Any shock bigger than the Bilstein 2" will probably hit the sides and need the hole enlarged.
Worked pretty good this weekend up at kelly flats, and I'm slightly unseating at full droop, so it will need to be retained.
1st Pic: posuer rock, TJ's lil' Sister standing in front, yes she's taller than 5'
2nd Pic: looking under the body...
TLCA#15530
