Old 10-22-2006, 05:19 PM
Chris's Avatar
Chris Chris is offline
Default Knuckle Rebuild
This knucklehead is going to rebuild the knuckles on my FJ62.
Yeah, yeah, I've read the FSM, watched the 80 rebuild DVD and anything else I can here and on mud.
Still I'm intimidated and gladly offer beer, pizza, whatever for a bit of assistance while gaining experience. Since I'll be tearing it apart I also have new rotors, calipers and pads.
Timeframe? Days, nights, anytime this coming week.
Where? My son-in-laws garage in Aurora
Thanks!
Old 10-22-2006, 07:13 PM
Get a seal puller if you don't already have one. Screwdrivers are bad substitutes. And if you are planning on disassembling the bell, just buy the pipe you'll need to pop the inner/outer axles apart. I tried the whole vise/punch/hit it in the right spot bit, it's not worth it. I'll buy you if you take longer than me, 27 hours total
Old 10-22-2006, 08:27 PM
Chris's Avatar
I think I have a few SST's lined up and do plan on buying a seal puller.
disassembling the bell? - buy the pipe? Now I'm adding more hours since I don't know what you're talking about
27 hours? Doesn't sound too bad to me. I just may pick up drinking again and the first will be on you!
Old 10-22-2006, 08:31 PM
You know, getting the 6 balls and cage separated to make sure the inside moving surface of the birfield is completely clean. I mean since you're all the way in there you might as well take the extra five minutes and make sure it's done right. It's good experience too . You have to break the snap rings on the inner axle so you can slide the birfield bell off. I can't believe at least the DVD didn't talk about it
Here is what I'm talking about, the thing is this procedure takes about 5 seconds whereas any other way of separating the bell/balls/cage takes ???? I never was successful, but spent about a 1/2 hour with the vice. With your rebuild kit you should have gotten new snap rings...
Old 10-22-2006, 09:18 PM
Chris's Avatar
Yeah, they skipped that in the video but I'll take the 5 minutes or 45, or 120.
Old 10-22-2006, 09:21 PM
Having a partswasher is very helpful. If not you'll want about 5 cans of brake cleaner per side. Have 3 5gal buckets and many rolls of the blue throw out paper rags. You don't need to separate the axle/birf. It'll take you 6 hours for the 1st side and 3 hours for the other. Check that you can get the 4mm bolts out of your hub before you begin your project. That got me as I had to replace hubs also $100 I didn't budget. Get a few punches and razorblades, gasket remover. Cardboard and lots of it for your garage floor.
Old 10-22-2006, 09:40 PM
Chris-
TP for the goo in the axles... works great.
I could help next week on Tuesday as its my day off, but no can do this Tuesday.
This is not a hard job just messy. You can do it man!
Drew
Old 10-22-2006, 11:33 PM
Man Jerk Man Jerk is offline
I can't believe no on has recommended latex gloves. Your gonna need em.
Mark Janzen
Member of:
http://www.mntoyx4.com
http://www.coloradolandcruisers.org
86 4runner
Old 10-22-2006, 11:48 PM
You using the whole fist there doc?
Old 10-23-2006, 02:19 PM
Chris's Avatar
Thanks to you all for the suggestions, looks like it'll be fine. I'll shoot for getting it done in under 27 hours.
Drew, if I'm not done by next week I may call on you
