Old 12-09-2006, 07:26 PM
Default Starts then immediately dies... stumped.
Howdy folks-
Well, I just got into my cruiser to fire it up and it isn't acting right. I know all I need is spark, fuel, and air... so here is what I know.
Issue started a few days ago, then went away. It happened once before tonight and then fired right up, tonight I couldn't get it to go. This is literally the first time ever it didn't start on the first or second try.
My fuel level in the sight glass on the carb is half way. Good.
I have spark at all the plugs, verified with inductive timing light. Good.
The truck just starts and dies, choke out, pedal to the floor once, crank, crank, Varooom! dead.
Same with the choke out or in.
If I try to crank, crank, and tap the gas, same thing.
Waited for a long time to make sure we didn't flood the carb, dead.
I can see a small leak on the front of the carb where the throttle linkage "rod" runs through the base of the carb and is attached on the front outside face of the carb. Maybe one little drop per starting attempt... not good, maybe a vacuum leak? Sprayed carb cleaner on the leak while firing, no difference.
The interior or "choke" side of the carb looks pretty dirty.
I can't see fuel getting sprayed into the throat of the carb when starting and pumping the gas pedal... shouldn't I be able to see it spray?
All vacuum lines are connected, verified.
Here is what I still need to check:
That the fuel is coming into the carb, and for a dirty fuel filter.
FWIW, I installed a radiator today but it was a simple swap.
Kinda at a loss here, any thoughts are much appreciated.
Thanks in advance.
Old 12-09-2006, 10:20 PM
74fj40's Avatar
74fj40 74fj40 is offline
hmm no spray when you pump, could it be the accelorator pump?
2005 Silverado 2500hd Duramax
1972 Toyota FJ40
1967 Porsche 912(100% stock)
[/font]
Old 12-09-2006, 11:44 PM
I would bet the bank on igniter or ignition module. While starting the distrib gets a hot charge that make a hotter spark. As soon as the key is released the ignition drops to normal mode.
Old 12-10-2006, 12:35 AM
Romer Romer is offline
see if the plug is loose on the coil or at the dizzy. Mine worked its way loose once when I swapped the battery and it still looked connected.
Old 12-10-2006, 01:28 AM
Coolio-
Do you mean my ignition switch in the cab could be bad? Or do I need to check it at the ignition module attached to the coil?
Romer-
Thanks man, yep checked them both... I was hoping that was it, but I am getting spark when the key is turned over.
Thanks guys!
Drew
Old 12-10-2006, 07:14 AM
IanB's Avatar
IanB IanB is offline
Is the float bowl still full immediately after it dies? You should be able to hear the fuel spraying into the carb with the engine off and pulling the throttle linkage.
1976 FJ-40
2001 UZJ-100
Old 12-10-2006, 07:55 AM
Have you checked the fuel cutoff solenoid on the carb?
Old 12-10-2006, 10:12 AM
Originally Posted by Rezarf
Coolio-
<snip>Thanks guys!
Drew
No....yes...
Old 12-10-2006, 11:54 AM
Kevin-
I have the later fj60 ignition in my rig, does that make a difference, I am kinda clueless on how to check the igniter.
Can anyone try to shed some light on the process for me?
thanks!
Old 12-10-2006, 01:29 PM
I doubt it's the ignitor or the coil. you need a multi meter to test the ohms on the ignitor. It's an easy test in the fsm.
Tighten all the manifold bolts. If you flood it you might pull the plugs and clean them up.
I would pull a plug and make sure you have spark vs relying on the timing light.
The butterfly rod will leak if your pouring fuel/pumping the accel alot. You should be able to see fuel dropping into the carb.
I would try and use a small bottle of gas. Start it and feed the engine with gas from your little bottle to keep it running.
How much vacuum are you pulling when running?
