Old 12-10-2006, 02:51 PM
Good tips Wes.
I am without a factory manual, but I do have a multimeter. I assume I am looking for obvious drop after start up?
I will run through your list, is sounds like good places to start.
Thanks man, hows the baby?
Drew
Old 12-10-2006, 03:18 PM
coil -
with both contacts on either side of the coil outlet. (the 2 with wires and nuts)
resistance w/o 2.6-4.0 ohms
w/ 1.3 -1.6 ohms
secondary - in the coil outlet, + on the black wire at coil
w/o 6-9.0 ohm
w/ 9.5 -14.5
external, contacts on the 2 nuts facing out like the coil
1.3-1.7
Ignitor + on the top nut, the one without the black wire going to the coil. turn the key to on and you should have 12v.
Old 12-10-2006, 04:03 PM
Thanks Wes!
FWIW, I was out messing with it. Same results from where I left off last night. Starts then immediately dies.
So, I got out and played with the wires a bit, just checking for anything loose at the coil/ignitor, and VAROOOM!
Runs like a champ. I am going to clean all the connections and try the volt meter.
Wes, I really appreciate the info man. Where can I get a FSM?
Thanks!
Drew
Old 12-10-2006, 05:59 PM
cool, glad it was simple. Spread open the connection on the wire that goes to the coil a tad so it's a nice tight fit.
You can buy the original Factory Service Manual (FSM) at:
Toyota Material Distribution Center
750 West Victoria St
Rancho Dominguez/Compton, CA 90220-5538 USA
1-800-622-2033
(outside CA)(M-F: 7-5 PST)
1-800-443-7656 (inside CA)
1-310-818-4630 (in or outside CA)
The 2f I think you want is pub #98126 (at least the one I havefor my 76)
You can always try ebay and find one of the smaller grey cover books to match the vintage.
http://search.ebay.com/search/search...tSearch=Search
Old 12-10-2006, 09:06 PM
Thanks again Wes!
I will be bidding on the manual using my Ebay sniper technique.
Drew
