Old 01-07-2007, 09:05 PM
brassos
Guest
Posts: n/a
Default hello all, from a new f-40 owner
I just took possession of a 72 f40. The rear sill is suffering from the usual rust cancer. Can I get a few suggestions for a good place to get a replacement part to weld in? The tire is mounted on the right rear.
Thanks in advance,
Old 01-07-2007, 09:06 PM
brassos
Guest
Posts: n/a
Default answered with search
found the info i needed, but feel free to chime in.
Check out Jeff Zepp's page and tech tip on replacing the rear sill on his '71 FJ40
Old 01-08-2007, 12:03 AM
There's a bunch of places, to name a few...
Rocky Mountain cruisers
Cool Cruisers
Heritage
canadacruisers
Real steel cruiser parts
Old 01-08-2007, 08:34 AM
Romer Romer is offline
Rocky Mtn is in englewood and they have a web site you can check parts and prices. You can then order and go pick them up and Ron will spend time with you answering any questions. That would be my recommendation.
Old 01-08-2007, 10:13 AM
Welcome to the board. Have fun with the fj-40.
Old 01-08-2007, 10:25 AM
Before going crazy trying to make it look good. Spend the time and money to make it safe. Start with brakes, wireing, fire extinguisher, seatbelts, cage, pinion nuts tight, All bolts and nuts tight for that matter. Batery hold down, Belts and hoses. If its body is rusty there are usually other issues that need addressing. Just my .02. Beauty is more than skin deep.
