Old 01-18-2007, 12:39 AM
minimal kinetic energy loading means friends/family hopefully won't be beheaded if cable fails!
Cable failure falls to the ground and is a non issue. I've had a winch cable fail with sever tension and it's a no biggie. That jacket won't do anything on the cable. If anything you want it as close to the mounting point as possible to help slow or cushion a flying failure at the mounting point. Even then I dunno if it will help.
The projectiles that kill are poor mounting points and their failure there.
Old 01-18-2007, 08:31 AM
Jenny Cruiser's Avatar
How often do you have to replace syn rope? I can't imagine it lasting long with prolonged exposure to the elements.
Old 01-18-2007, 08:35 AM
Beater's Avatar
Beater Beater is offline
good points wes, When I went to "recovery school" whatever that was.. They preached the recovery points, not the winch line. It has to do with where the break is in relation to the force point, and the mass at the focal point of the break.
anchor points, clevises and winch hooks are the danger points. I have seen several recoveries like the one in uncle ben's pic, and while I am sure it does something, the way we were taught was to use a blanket (you know, the old one you keep in the truck for emergency snuggling with your co-driver or dog when stranded) laid out full length over the line, so that when the line snaps, it will lower the fulcrum of the snap, in effect shortening the radius of the lever, resulting in less transfer of energy, and or less distance for the projectile.
Not a common failure, but statistically more apt to happen with frayed cable OR rope.
There are a lot of myths out there in regards to this subject, and I am far from a scholar on it, but the times I was schooled in it have stuck in my head.
Once, in air assault training, we were rigging a cucv blazer for deployment with a blackhawk. Cocky kid, (unbelievably not me) decided to not pay heed to the instructor, and almost lost his hand due to a bad lift point connection.
I definitely took the subject seriously since then, especially since I realized that we were lucky that it was just his hand, as had the bird fully lifted, it would have likely killed or injured one of us on the ground, but his screams had the instructor lower the bird.
stepping off soapbox now...
Old 01-18-2007, 08:50 AM
Bobzooki's Avatar
Bobzooki Bobzooki is offline
Replace it? Heck, I think it may outlast my rig!
From Rockstomper's Website (www.rockstomper.com):
How does synthetic rope hold up to UV exposure?
Amsteel Blue has a proprietary urethane-based coating, factory-applied, to help it resist UV radiation. Additionally, Amsteel Blue was not actually designed for the 4WD industry; it was developed for offshore commercial fishing purposes, where it would be exposed to nearly-constant sunlight. Because of these design criteria, it resists UV exposure very well.
Bob Gassert
Sold the Gnewt.
Bought a boat.
Old 01-18-2007, 01:04 PM
ginericLC's Avatar
ginericLC ginericLC is offline
I think his primary reason for suggesting not running the hawse fairlead was due to the heat that is generated by the friction. Heat kills synthetic winch rope. He also chatted about how spooling it out with the motor would wear the brake in the winch quickly and the heat generated would harm the synthetic winch rope. It was an interesting article. I already bought a hawse aluminum fairlead in anticipation in switching to the synthetic winch line. Maybe I'll just use my rollers? I haven't decided yet. I do have a friend who uses the synthetic on his Jeep with rollers and he has never had an issue.
