Old 01-18-2007, 07:22 PM
arthog arthog is offline
Default need service for a 85 toyota truck.
any recomendations? for a head gasket and timing change. near golden or close to.
Terry
Old 01-18-2007, 10:01 PM
Joe Calleja at Colorado Toyota Specialists in Aspen Park. (303) 838-4772. He's a Rising Sun member and expert on 22REs. I've used him a number of times for my daughter's 85 runner when I didn't have time to deal with it, including head gasket and timing chain.
Old 01-18-2007, 10:08 PM
don't know about the head gasket, but the timing chain is easy to do.
Old 01-18-2007, 11:35 PM
Doing the timing chain on a 20R/22R/22RE requires removing the head...and the rad, and... :-(
Bummer thing about these is that chain itself is usually fine, it's almost always the tensioner and guide that needs replacing.
While all the manuals say you MUST remove the head to do the chain, Joe told me about a trick he knows of where he doesn't have to actually remove the head. I looked at it and looked back at him and scratched mine. He then confided that it was quite a trick and was actually a PITA.
Old 01-19-2007, 08:30 AM
i didn't have to remove the head or pan when i did mine. it was a piece of cake. frank morgan from pederson toyota told me they never remove the head to do t/c
Old 01-19-2007, 09:11 AM
The HGs have a service life, however, and it's worth it to replace the HG while you're in there - then forget about it for another 120K. A weak HG can erode the head and block, which starts getting very expensive. Don't ask me how I know that - let's just say the Chili had the shortcut version prior to my purchasing it.
KDěRCH
Old 01-19-2007, 10:45 AM
Three Wheel Ben's Avatar
X2 Cheap insurance.
KC0ZBI
Old 01-19-2007, 03:14 PM
isotel's Avatar
isotel isotel is offline
im about to tackle this job on my 4runner 22re.. I was under the assumption that if you pull the head for a gasket, you should send the head to a machine shop to have it looked at and milled.. I dont know if i want to get into that.. My main issue is that the front timing chain cover leaks like Crazy.. and i got almost 160k on the clock..
Old 01-19-2007, 05:10 PM
[quote=DaveInDenver;24987]although some people say you can just bend the front lip of the pan. IQUOTE]
i didn't have to bend mine
Old 01-19-2007, 05:35 PM
the 22R-E is in fact a non-interference engine and when the chain does break at least you don't crunch valves.
First-hand experience: The 22RE IS an interference engine. Timing chain slips and you have bent valves and gouges on the piston tops. $$$
