Old 01-23-2007, 05:11 PM
lfd270ben's Avatar
lfd270ben lfd270ben is offline
Default 5.29 install lots of grinding?
So I was ordering my 5.29s and kurt told me that It takes alot of grinding on the rear gears or housing Im not quite sure which I searched mud for like an hour and could not find pics any help explaining it to me would be great.
Thanks,
Ben
Ben
Colorado
1961 Dodge Power Wagon Town Cummmins 4BT, NV4500, NP205, Dana 60's
SOLD! 72' FJ40 little red 40 with some extras
2008 Dodge Ram Mega Cab Cummins
18 foot P&J flat bed
Old 01-23-2007, 05:53 PM
Thanks,
Ben
Only in one spot so you can slide the pin in and out.
Old 01-23-2007, 10:55 PM
Man Jerk Man Jerk is offline
You basically need to grind down one of the teeth on the ring gear.
Mark Janzen
Member of:
http://www.mntoyx4.com
http://www.coloradolandcruisers.org
86 4runner
Old 01-24-2007, 10:50 AM
Ben, why are you going for gears as opposed to some sort of t-case upgrade?
Old 01-24-2007, 11:03 AM
grinding a ring gear
Old 01-24-2007, 06:28 PM
lfd270ben's Avatar
I decided to go with gears because it fits my overall goals for my truck and for now I need all the help I can get while I still have the f engine and once the F blows up in will go a 4bt/ nv4500/dana 300, and once I wear out these tires on goes a set of 39.5's and 4 link rear
Ben
Colorado
Old 01-24-2007, 06:31 PM
lfd270ben's Avatar
thanks for the link it was just what I was lookig for.
Ben
Colorado
Old 01-24-2007, 09:31 PM
powderpig's Avatar
You can avoid grinding too much by think this out, play with moving the ring gear around to see what amount you can grind. This will be a visual thing as the gear will usually not sit very far on the carrier. So if you can visualise(not proper spelling) when you rotate the ring gear, you will grind less. Other wise heat it, plop it and grind it. Later robbie
Old 02-10-2007, 06:04 AM
lfd270ben's Avatar
This might be stupid but couldnt I avoid grinding all together by just installing the spider gears and pin (loc rite in my case) and then pressing the ring gear on? wouldnt this work fine unless the pin broke or the loc rite failed
dont see any reason I would need to remove it?
Ben
Colorado
Old 02-10-2007, 07:13 AM
How do you plan on putting the c-clips on to hold the axles in? You only need to grind on the rear as the front is full floating.
