Old 01-25-2007, 08:52 AM
78FJ40 78FJ40 is offline
Default Fuel Neck Restrictor
Moved here from Kansas City recently and am trying to get my FJ40 licensed here in Colorado. I need to find a restrictor for the fuel neck on my Cruiser. Any suggestions?
Old 01-25-2007, 09:02 AM
Beater's Avatar
Beater Beater is offline
interesting. I thought that as long as the filler neck is orignal to the vehicle, as factory delivered, it would be legal here in colorado
Old 01-25-2007, 10:29 AM
powderpig's Avatar
My 80's fuel neck is from OZ(dual filler from a diesel, no restrictor) and has not been rejected over the last fews of emissions testing. The main thing I have seen them looking for is if the cap will pass the vaccum test(if one exists for your year). In the past I usually have found them at either napa or carquest. May need to order one, if you really need it. later robbie
Old 01-25-2007, 10:56 AM
Have you actually been rejected or did someone tell you this was needed?
x2.. I've never had them check for a restrictor not to mention it's not a factory item. All they ever do is test the fuel cap for pressure like robbie says.
Old 01-25-2007, 12:03 PM
napa, checker etc used to sell little ones that you pund into place
Old 01-25-2007, 12:15 PM
Mine passed without it. They didn't even notice mine is desmogged with no air pump, cat, etc. I don't think the kid doing the test had ever seen a carburated engine.
As long as it passes the sniffer, you should be good to go. And get collector plates after you pass so you don't have to go back.
Old 01-25-2007, 01:54 PM
Thanks for the help guys. I hope to actually make it to the February meeting so I can join the club.
This whole licensing deal has been an ordeal from the start. My FJ40 has a brand new Chevy V8 with Fuel Injection from an 89 Chevy Pickup. For starters when I took my rig to the Castle Rock testing location they immediately gave me the name and number of a guy in Aurora that I needed to contact to get the instructions that would tell them how to even test the vehicle because of the engine swap. Well I made the drive up to Aurora yesterday afternoon to let the guy look at it. He filled out the paper work and one of the things that he put in the instructions is that I needed a fuel neck restrictor. He also suggested that I get Antique or Collector plates so I can avoid all this in the future. So because it is in the instructions that is why I have to get one. Totally stupid because you can even buy leaded gasoline at a filling station anymore. You'd have to goto an airport to buy it and why would I want to pay $5 or more per gallon of gas? I also had to get a CAT installed on the exhaust.
Old 01-25-2007, 02:31 PM
Originally Posted by 78FJ40 View Post
...I took my rig to the Castle Rock testing location they immediately gave me the name and number of a guy in Aurora that I needed to contact to get the instructions that would tell them how to even test the vehicle...
I would try going to a different testing location.
Old 01-25-2007, 02:42 PM
Beater's Avatar
ok, that's your problem... it's not stock. Colorado law reads (roughly) that they can't fail you if your vehicle was sold that way originally. If it's a chevota without collectors plates, your in for a rough time.
Old 01-25-2007, 03:18 PM
Ahhhh....the puzzle piece has been found! You are correct in the fact that now the referee specified the filler neck, you will have to comply. Sounds like you got away cheap compared to what he could have demanded! When I first had the referee check out my V8J-62 after the transplant he nailed me for the factory heat riser I had removed from the stock air cleaner so the snorkle would be sealed. What a jerk as most folks throw open element air cleaners on when they do conversions and here is a sano install with a functioning and sealed air filter setup. I think they must have to find something wrong with each application. I would do the cheap insert Ige mentioned and be done with it.
