Old 01-25-2007, 03:21 PM
I would do the cheap insert Ige mentioned and be done with it.
And then remove it 20 min later
Old 01-26-2007, 06:18 PM
78FJ40 78FJ40 is offline
Well I found the restrictor that I was needing. JK Automotive in Englewood is apparently the only one in the whole state of Colorado that has these little gems. They look like a throwing star with a hole in it and are made of spring steel. You basically insert it into the Filler Neck through the Gas Cap Opening and then wedge it into place. The spring steel drives the points of the restrictor into the Filler Neck. With this in place I will be heading down to the Castle Rock inspection station in the morning. Hopefully I will meet up with success.
Old 01-26-2007, 06:54 PM
Good luck!
Old 01-27-2007, 02:13 PM
Yeah it passed! Now onto the DMV. See you at the February meeting if I get back from Washington in time. Thanks for the help.
Old 01-28-2007, 06:34 PM
He filled out the paper work and one of the things that he put in the instructions is that I needed a fuel neck restrictor. <snip> I also had to get a CAT installed on the exhaust.
That's too bad. An original 1978 with the factory 2F does not need a restrictor or a cat, they weren't required until 1979. Glad you got passed though, congrats!
Old 01-29-2007, 10:12 AM
SteveH SteveH is online now
>That's too bad. An original 1978 with the factory 2F does not need a >restrictor or a cat, they weren't required until 1979. Glad you got passed >though, congrats!
I was told otherwise, and it was checked every year on the e-test of my 6/78 FJ40 - no cats, but restrictors are required and checked. The little book of 'what's supposed to be on your truck' showed restrictors. The PO even replaced the filler neck with a new one (to get a restrictor) and hammered one of those 'replacement restrictors' into the neck of the ConFerr tank.
Now that the Dems have taken over Colorado politics, I wouldn't ditch all your emission stuff just yet (those of us in El Paso and a few other counties). I'm sure some liberal will find an excuse (other than clean air) to reinstate the e-tests around here - job security for mom-and-pop repair shops, for instance.
Steve
