Old 01-29-2007, 03:56 PM
CardinalFJ60's Avatar
Default got the 40. here's the 1st question of MANY.
Although the 40 I just picked up has been 'restified' quite nicely...it needs a little TLC after getting none for a last several years. I'll post up a nice poser driveway pic later...but I GOTTA FIX THIS SUPER HIGH IDLE.
I have a super high idle and when going through the process I normally do - set the fast idle, then set the 'regular' idle - the adj. screws don't effect the idle at all.
Tonight I'm going to check to see if the secondary is stuck open. Is there anything else I should check? Like, are there return springs or something I need to check out?
Thanks!!!
Old 01-29-2007, 03:58 PM
Congrats on the new Cruiser
Sorry no help on the idle issue but can't wait to see pics!!
Old 01-29-2007, 04:05 PM
Romer Romer is offline
Try this
http://forum.ih8mud.com/showthread.php?t=26635
Old 01-29-2007, 04:23 PM
Default sweet. thanks.
in all my mud searches - I didn't see this, thanks!!!
Old 01-29-2007, 04:39 PM
It was in the 40's section FAQ titled "Updated Carb tech"
Old 01-29-2007, 04:42 PM
Default thanks Ken, this helps...but...
I can't get the idle to change at all using those adj. screws. I can turn'em all the way each way, and it doesn't do anything to the idle. I can't get the sucker to idle below what sounds like "ludicrous idle-speed". I don't have a tach, but it sounds like 1200+rpm. OH, the only thing I can do to effect the idle speed is lifting up on the skinny-pedal.
Let me know if you think I'm on the right track for tonight's fun in driveway.
1. clean carb
2. Check if secondary is stuck
3. test for vac leaks using procedure in link provided by Romer
4. I don't have timing gun, tach, nor vac guage...so that stuff is outta the question.
Question: It's got headers, anything special I should check given that?
I'd like to get to the point where I can at least change the idle speed using the adj. screws. Right now, she just ROARS, really loud.
thanks again!
Old 01-29-2007, 04:58 PM
Beater's Avatar
Beater Beater is offline
first thing: buy lots of carb cleaner.
second thing: spray said carb cleaner around carb and vacuum lines
third thing: fix air leak....
Old 01-29-2007, 05:09 PM
treerootCO's Avatar
Event Coordinator
If the pedal affects it, you need a return spring. The engine is probably sucking the butterflies open.
www.root45.com
www.risingsun4x4club.org
TLCA #14133
Old 01-29-2007, 05:39 PM
x2 on what Mike said...If I understand you right when you lift on the pedal the RPM drops down to normal, or what sounds like more normal? Then when you let the pedal go the idle goes back up?
Maybe the spring is 'sprung' or popped off or?? Remember I am mechanically challenged but this seems to make a lot of sense and would seem to coincide with the adjustment screws having no affect.
http://www.sor.com/sor/cat042b.tam?xax=21326
Old 01-29-2007, 08:06 PM
treerootCO's Avatar
Event Coordinator
the spring is on the carb. It is listed in the SOR link above but kinda hard to see. The spring is not on the pedal itself even though some have one there as well.
www.root45.com
TLCA #14133
