Old 02-18-2007, 09:11 PM
Deerskin Deerskin is offline
Plug #4 looks normal. The valve springs are good, nothing broken or collapsed. That was my initial thought from Matt's description of blow-back thru the carb. The entire valve train looks good except for the failure to seat as previously discussed.
'96 FZJT80, Locked
Old 02-18-2007, 09:23 PM
I know the valves can't hit a plug, but if the heads use replaceable valve seats and a seat came loose, banged around head area as the valve cycled and fuel air charge is pumped thru the cylinder, the question is; could a loose valve seat reach the plug to inflict the damage as seen on #5 and #6? Kind of like the valve seat doing the hula hoop around the valve stem as the valve cycles.
It's all probably interesting discussion until the head comes off.......
'96 FZJT80, Locked
Old 02-18-2007, 09:26 PM
Wow. Great pictures, Matt. The backfire out the carb is because that valve doesn't seat. Valve doesn't seat because there is a piece of something big in it. The "something" banged around a while and damaged the plug before it got stuck. The gap on that rocker is because the valve won't seat.
The red on the plug is OK. That's just addatives. probably from running the HEET for 20 minutes.
Now how you got mechanical damage in 3 cylinders at once: I don't get it. I guess it is possible that when the valve got stuck open chunks from the bad cylinder got pushed back up into the manifold and sucked down another jug.
No matter what, you're pullin' the head on this one. With that much damage, I think you'll find some beat up piston heads as well as the head damage. Sorry. It may very well be time for a different engine.
KD0FDS
Stephen
  #24
Old 02-18-2007, 11:23 PM
put new plugs in... adjust the valves and see how it runs
WØREK
  #25
Old 02-19-2007, 06:26 AM
The intake valve on #5 is either bent or has something caught in it. I'm with Steve on this - pull the head. It could be a chunk of a broken spark plug or something that got sucked in through the intake manifold. I vagely remember a Mud thread about some bolt in the carb coming loose and ending up in a cylinder. This might be similar.
  #26
Old 02-19-2007, 12:12 PM
Disappointing
If your pistons aren't shot, you'll only be down for a week if you pull the head. If you simply replace the plugs, you may get it to run again and do further, much more severe damage.
Originally Posted by nakman
  #27
Old 02-19-2007, 01:03 PM
treerootCO's Avatar
Event Coordinator
I have an empty trailer behind the dmax today. Let me know if you wanted to move the Cruiser to your dad's place today. I have extra F parts laying around. Some of them will cross over to the 2F engine.
www.root45.com
www.risingsun4x4club.org
TLCA #14133
  #28
Old 02-19-2007, 02:06 PM
Yeah, definitely not starting it again until I take the head off and see what's going on.
Thanks Root, not today but soon I might be giving you a call
Anybody wanna come gawk at it while it's still up here? I guess the mystery is no longer as much of a mystery now that I pulled the plugs at Zepp's suggestion...
  #29
Old 02-19-2007, 02:42 PM
treerootCO's Avatar
Event Coordinator
I found the thread on mud and I think Grant is right on this one. Your cam probably slipped.
www.root45.com
TLCA #14133
  #30
Old 02-19-2007, 11:17 PM
I have never had a 2F apart so I can't speak from direct experience on this one, but I have had a bunch of old school Honda motorcycle engines apart. Many have long cam chains and jumping a tooth isn't unheard of. When they do, the valves contact each other or a valve and a piston contact, causing some disintegration/breakage. Likely cause of your plug damage. I would get the head off and take a look to see what's in there jamming in the valves.
Oleg has a rebuilt 2F for sale
