Notices
  #261
Old 03-19-2008, 05:45 PM
Originally Posted by MDH33 View Post
Are there any problems with the stock axles and brakes? I would leave it stock for now and get it running well as Jeff suggested. You'll have a blast in Moab with a stock 40.
I have spare '73 driveshafts if you need some.
You can order all new OEM brake parts to do a full service cheaper than you might think. I did my '73 this fall in an afternoon, replaced all the shoes, turned the drums, replaced the wheel cylinders and added aftermarket stainless braided lines. Once adjusted properly, the drums work great.
Now that I think about it, I have 6 (!!!) drums already turned and sitting in my garage. This might save time - swap out the old drums for turned ones, then turn the old ones whenever.
  #262
Old 03-19-2008, 05:47 PM
IMO, you should table the locker. Learn to drive the truck open first, you'll be a much better driver in the long run.
X2!
  #263
Old 03-19-2008, 06:07 PM
Originally Posted by timmbuck2 View Post
1. Get Engine Running and desmogged.
Yep, if you run into snags there, the whole plan falls apart. Focus on that like a laser.
3. exhaust. Jeff said "check - Note that OEM muffler/tailpipe is (was) still avaiable from dealer for about the same (inexpensive) $$ as aftermarket muffler shops, and it bolts right up!" So I just give Stevinson or CDan a call and order it up??
Whilst the muffler and tailpipe and all brackets and hangers/hardware were still available last time I ordered them in new from Stevinson, the down pipe is not! Make sure you have a down pipe!
4. check and overhaul brakes. another call to Stevinson or CDan and have beer as a bribe for help.
New shoes are readily available from the dealer. Cylinders are sketchy if you want new ones. I know the ones on my 71 are no longer available from Toyota but ones for my 76 and 78 are. I've had decent luck with CCoT's cylinders for my 71.
5. gas tank. have a couple. need to take to Denver Radiator (?) and have them checked and maybe boiled and sealed.
Definitely will spoil your plans if your tank is either full of crud or leaking.
IF I can get all that done...
1. Either move locker from FJ55 axle to the 40 or throw on the whole axle. Would involve some more brake work as that axles has the brakes stripped. No hurry for the front disc brake axle as that would add a lot more time.
Again, my advice is to prioritize this lower. As Ige noted, moving the diff or just the locker (assuming Lock-Right?) is MUCH less work than the axles housings, it's still more to add to the above.
2. lift
Wish list
3. front locker
Wish list
4. sliders. if SROR has some that are ready quickly, cool. If not, won't worry about it.
As I wrote, 40s really don't need them, that's a wagon thing. If you bash up your running boards some, whatever, who cares? All the years I've done Moab I've never messed up my running boards. Bashed 'em up pretty good on local trails though, but nothing a BFH can't fix.
One last bit of advice. Stare at the rig a lot. Mentally note what's not there and let your eye wander around your garage for what you have, and don't have, so you know what you'll need. Like bolts for the tranny to bellhousing (and yokes to driveshaft - they're special bolts and nuts). Little crap like that is such a time sink if you don't think about it in advance. Fuel line, heater hose, gaskets, air cleaner, so many details. Make a list! Be more specific! Like, for the exhaust, you'll need the donut (gasket) that goes between the manifold and the downpipe. And nuts and washers! Etc.
  #264
Old 03-19-2008, 07:03 PM
heck, on a 40, if you bash the rockers, you just cut em off
  #265
Old 04-02-2008, 10:06 AM
timmbuck2's Avatar
Thanks SO much for the advice everyone. Due to the lack of time and other commitments I have, I will not be taking the 40 to Moab. I will continue to work on it to get ready for Rubithon, so that gives me 6 additional weeks to work. I would like to get a minor lift on the 80 and maybe a rear bumper, but I could take the 80 as is....after the steering is fixed due to the drunk asshat who hit me.
* 00 LC
* 99 Saab Convertible
* 76 Piggie
has a 2008 FJC
KDěTIM
  #266
Old 04-02-2008, 10:27 AM
Shark Bait's Avatar
If you need any 40 parts, let me know.
Chris Hatfield, TLCA# 2768, KCěZAB
'11 Tacoma, '12 GX460
  #267
Old 04-02-2008, 11:17 AM
ianacole ianacole is offline
Send a message via AIM to ianacole Send a message via MSN to ianacole Send a message via Yahoo to ianacole
Still looking for a 4-speed? This popped up on CL today...a bit spendy, though: http://denver.craigslist.org/pts/625848704.html
