Old 03-20-2007, 02:20 PM
kbabin1 kbabin1 is offline
Default Headlights not working - bad ground?
Hello, this is my first post here - helping a relative with a 1988 FJ62 Land Cruiser.
Stepdad hit a bump, headlights went out, another bump, headlights back on. Now, headlights are dead.
Fuses all checked, fuse links look good. Replaced the rust colored relay because it was buzzing - still not working. Another headlamp relay is buzzing, along with blower motor relay.
Here are the symptoms:
1- very dim light on the low beams now, nothing on high beams.
2- Light switch activates blower motor.
3- Turn signals and blue bright light on dashboard stay lit. Right turn signal on dash blinks fine, when switched to left turn signal it blinks very fast.
4- I've sprayed WD-40 on column switch to try and clean it. I've wiggled wires around and checked for shorts on all front bulbs and rear, driver side lights.
I'm told it might be a ground - but have no idea where to look. Also, both left and right side marker lights are disconnected.
Any ideas?
Many thanks!
Jamie
Old 03-20-2007, 02:37 PM
I'll take a wild guess based on a Toyota generalization...
the minitrucks use a ground through the turn signal stalk. Not a good system. First place to check.
If that is it, an aftermarket headlight wiring harness with relay-switched large gauge wire feeding the lamps is far superior and worth the $$. Brighter lights, too.
KDRCH
Old 03-20-2007, 03:09 PM
timmbuck2's Avatar
...or just hit another bump....
* 00 LC
* 99 Saab Convertible
* 76 Piggie
* 1996 T-100 with 396k miles
has a 2008 FJC
KDTIM
Old 03-20-2007, 03:26 PM
Default lights
I wish I could hit another bump..LOL
I am familiar with the other lights. On another car I ordered a wiring kit, relay system and installed high-wattage eCode lights. It's like night and day.
On this truck I don't think that will happen. I think he wants to keep it going until he buys a Tundra this fall.
Tracing this short is a pain. Do I need to pull the steering wheel if we need to replace the switch on the column?
Old 03-20-2007, 05:23 PM
Default fj62
I pulled the steering wheel, took apart the headlight switch and sprayed it with WD 40 and reassembled it. No change. I have been racking my brain, trying to find where this thing might ground (or not be grounding).
Can anyone point me in the direction of a technical forum or group (if you guys cannot assist)? I am really surprised - I've been Googling a lot of key words and thought I'd come across a dozen good sites with breakdowns and pics of everything - but I haven't been able to find them.
Anyway, I am at a loss and any help is kindly appreciated.
Jamie
Old 03-20-2007, 05:38 PM
Shark Bait's Avatar
IH8MUD 60 Series Tech
'12 GX460
Old 03-20-2007, 06:16 PM
Default fj62
Thanks!
