Old 03-25-2007, 06:50 PM
Default Is MIP and NPT the same thing?
If I have a 1/2" MIP (male iron pipe) fitting, do I use a 1/2" NPT (National pipe thread) tap? Or is there a IP tap I need to get?
Old 03-25-2007, 08:21 PM
60wag 60wag is online now
It should be the same. JIS is close but a hair different. BSP is totatally different.
Old 03-25-2007, 09:53 PM
Convert's Avatar
Convert Convert is offline
They are the same
Dan Reinmuth
47 Bantam Trailer/RTT
71 FJ40 project
TLCA 13269
KØVRT
Old 03-25-2007, 09:59 PM
cool, thanks guys.
this is the captian speaking,
in case of water crossing, your sliders may also be used a flotation device...
Old 03-25-2007, 10:48 PM
Convert's Avatar
You better fill the front and rear bumpers on that NewPig for floation
Dan Reinmuth
71 FJ40 project
TLCA 13269
KØVRT
