Old 03-28-2007, 10:47 PM
engineerjoe engineerjoe is offline
Default can't get the J-arm off!!!wtf??!!
hey guys
i am installing my hi-steer arms onto my front axle ('85 PU axle)
and the passenger side came apart and went together easily but im having some trouble getting the drivers side J-arm off. it's loose and it moves ~.25" up but then stops and won't come off any farther. The studs don't look bent but they could be.
anyone else have this problem? any advice?
thanks
Joe
People are like slinkys; kind of boring but fun to watch when pushed down the stairs
Old 03-29-2007, 12:48 AM
lfd270ben's Avatar
lfd270ben lfd270ben is offline
double nut and back out the studs, or bust out the big pry bar but watch out what you mar up.
Ben
Colorado
1961 Dodge Power Wagon Town Cummmins 4BT, NV4500, NP205, Dana 60's
SOLD! 72' FJ40 little red 40 with some extras
2008 Dodge Ram Mega Cab Cummins
18 foot P&J flat bed
Old 03-29-2007, 09:28 AM
Are those cone washers holdin' you back? If so, pounding on the j-arm front and back does as much as pounding UP on the arms. also, I have found that jamming the little craftsman screwdriver into the groove of the cone washer will often open it up enough to get it to slide over the stud.
I had my steering arms off about 2 weeks ago. Banging on them only let them come up so far. I ended up prying between two shims (cheaper/ easier to repair) a little bit while I pounded on the front/back of the arm. The little bit of prybar tension is all it took to work the cone washers up off the studs.
Again, the big trick was pounding on the front and back of the steering arm. I use a 3# brass hammer all the time on my truck. It fixes lots of stuff.
KD0FDS
Stephen
Old 03-29-2007, 10:33 AM
the cone washers are out of the arm
Old 03-29-2007, 11:21 AM
Sounds like the part that positions the kingpin bearing is rusted in place on the bearing.
Bigger hammer.
KDØRCH
Old 03-29-2007, 11:22 AM
Have you blown a birf or two in that knuckle? Shrapnel tends to beat the pooh outta everything inside of the housing. If you have enough space try and use a disk brake pad spreader.
KØUBN
Old 03-29-2007, 01:44 PM
I havent used the axle yet - I don't know if a birf has been demolished in there. The pad spreader is a good idea - I will give that a try
