Old 03-31-2007, 03:58 PM
kvanoort's Avatar
kvanoort kvanoort is offline
Default Engine Removal
I'm almost ready to pull the blown F motor from my 1972 FJ40 project. I have everything disconnected but have a question about what should be removed behind the block. I'm planning to install a 2F and use my existing three speed tranny. Will it work to just disconnect the bell housing from the tranny or do I need to pull the engine, bell housing, tranny and transfer case as a unit? Thanks.
Old 03-31-2007, 05:00 PM
Shark Bait's Avatar
You going to have to move your flywheel to the 2F, which probably means removing the clutch first. It's probably easier to either pull everything as a unit, or drop the tranny/transfer case first and then pull the engine with the bell housing.
Just my .
'12 GX460
Old 04-06-2007, 05:55 PM
I'd drop the trans and TC first. Pulling all as one unit will be very heavy.
Old 04-06-2007, 06:35 PM
My vote is pull motor tranny & t-case together. As long as you have a good hoist and tall enough garage and at least one helper. Getting everything lined up to put it back together will be way easier. There are 2 motor mounts and 2 bell housing mounts to the frame. Tranny and t-case are only mounted to the bellhousing not the frame in any way.. ie tranny and t-case will fall to the floor and you'd have to support and stuff it from unerneath to get it back together. Can't stress enough height to celing. I took wheels off and put 78 fj40 on blocks with rotors an inch from the ground. took a couple times of shortening chains and closing garage door before I got it out. Front chain on hook , rears bolted to bellhousing/block bolts. Pulling tranny and t-case out the bottom is not much fun.
Old 04-06-2007, 07:00 PM
Pull it all together! It was designed that way and actually takes less time than separately!
Old 04-07-2007, 08:38 PM
x2, it is nearly impossible to get to some of the bellhousing bolts without pulling it.
