Old 04-02-2007, 04:47 PM
Default Winch line/cable
Pulled the XD9000 off my FJ40 for possible use on the LX
I noticed when I got the winch off that the wire cable is tweaked in at least one spot so replacement is in order (or I could shorten the cable).
Per Warn the cable is 5/16" x 100' standard (assuming original cable). I assume I should stick with that size and length, or can I go up to 3/8" x 100'? I've been looking at synthetic line figuring if I've got to replace the cable then synthetic might be the better option. I did a search on MUD and sent Warn this question but so far I've come up empty.
Any thoughts appreciated
Old 04-02-2007, 05:28 PM
Personally I'd stay the same and go up 50' in length.
Old 04-02-2007, 05:42 PM
Wes,
you think 150' of 5/16" cable/line would fit? I've looked high and low on Warn's site for the drum capacity and I don't see it referenced anywhere. I was figuring Warn would respond quicker to the inquiry so maybe I'll have to call them direct.
Old 04-02-2007, 05:50 PM
waggoner5's Avatar
I have a new cable and fairlead that you can have if you need one. Came new on my Warn 8000
Old 04-02-2007, 06:01 PM
Oh sure, TRY to keep me from spending money!
I'll keep that in mind and thank you very much for the offer
For some reason I'm being pulled to synthetic line but I hope it is not just because it is the "in" thing, looks cool, and I can justify doing so since my wire cable is tweaked.
Old 04-02-2007, 06:20 PM
waggoner5's Avatar
Dang , I can't even give this stuff away. I was even going to deliver it.
Old 04-02-2007, 06:32 PM
I take it you went to synthetic? What did you go with?
As for the wire cable...Is it 80' or 100' in length? I may take it off your hands yet just to get the winch back to working shape and decide from there.
Old 04-02-2007, 08:11 PM
waggoner5's Avatar
Yes I went with synthetic. I am pretty sure its 100'.
Old 04-02-2007, 09:35 PM
Make a great zip line!
Old 04-02-2007, 10:20 PM
ArloGuthroJeep's Avatar
ArloGuthroJeep ArloGuthroJeep is offline
For those not familiar with winchline.com - this guy makes super cheap synthetics compared to Warn's etc...
A few guys in my club have run his line for a few years w/o problems.
http://www.winchline.com/winchlines.htm
-Ryan
