Old 04-02-2007, 05:47 PM
74fj40's Avatar
74fj40 74fj40 is offline
Default Must have missed a couple of gaskets...
When I replaced the 3FE in my sons FJ62, it started to leak - oil and transmission fluid - not just a couple of drops either....
I replaced the timing cover gasket and the oil pan gasket - no improvement.
My son is home from Western State starting on Thursday - think I'll pull the engine and see what gives - If anyone with 3FE experience is around Thursday, Friday or the weekend, I could sure use some help troubleshooting the source of the leaks..... and good food provided!
TIA, Rob
2005 Silverado 2500hd Duramax
1972 Toyota FJ40
1967 Porsche 912(100% stock)
[/font]
Old 04-02-2007, 06:04 PM
Rob, one of the best things I can suggest is get after it with a good engine degreaser, and a pressure hose and get it clean.
Once clean, let it sit for a while or run at idle then, start to look for leaks. Gotta be easier than pulling the whole shibang.
That is a bummer, you will get it!
Drew
Old 04-02-2007, 06:24 PM
74fj40's Avatar
Yea - Thursday morning is degreaser morning - gonna need a case.....
You're right, pulling the engine is a big pain - done it a couple of times. If after cleaning we can see where all the leaks are coming from and don't need to pull it, we'll be v e r y happy!!!!!
I have a feeling we'll need to replace some seals around the transfer case, though....
Drew
1972 Toyota FJ40
[/font]
Old 04-02-2007, 07:13 PM
Crash's Avatar
Crash Crash is offline
Well, the transfer case doesn't have either ATF or engine oil in it so try to determine if it smells like diff oil or not. If I can help Rob, you know I will. No plans for the coming weekend unless the raffle truck needs work.
Old 04-02-2007, 07:21 PM
74fj40's Avatar
Thanks Steve - may have to take you up on your offer - it's definitely oil from the front - my guess is the timing cover gasket, and atf from the transmission - not too familiar with automatics, so not sure what that would be - I did replace the transmission pan gasket, so that's not the culprit....
1972 Toyota FJ40
[/font]
Old 04-02-2007, 07:24 PM
Did you mess with the rear main seal?
Old 04-02-2007, 08:26 PM
74fj40's Avatar
Did replace the rear main when we rebuilt the engine, but the oil leak seems to be from the front area.....
1972 Toyota FJ40
[/font]
Old 04-03-2007, 12:17 PM
Romer Romer is offline
Is it on one side more than the other?
Old 04-03-2007, 01:51 PM
74fj40's Avatar
Don't think so - seems to be coming from right around the timing cover, top of the oil pan area - very hard to tell until we give it a good cleaning....problem is, I've already replaced both the timing cover and oil pan gaskets and the leak hasn't improved, so I'm kinda stumped...
1972 Toyota FJ40
[/font]
Old 04-03-2007, 01:54 PM
Front mainseal?
KDěRCH
